Question about Washburn Music
Washburn guitar mg-20 pick up switch position 5 neck pick up no sound or noise humm or anything. all other positions and configurations work?
  • Anonymous Mar 22, 2014
    It makes a sound like Snow when a TV has the blank screen. It comes and goes, every few months it works just fine, other times i turn it on(guitar plugged in or not) and it makes a wild pew pew noise then goes to snow. This goes on until for some unknown reason it works fine again.
    New Friend:
  • 27 Answers
If everything is standard on that guitar then the only reason that pick up wouldnt work is because its a defective pick up or a wire is disconnected. it may also be possible that the selector switch is bad. take a small screw driver and tap the pick-ups in all positions while plugged in to the guitar amp and the volumes up ( not all the way) just loud enough that you can hear the tapping. you find the bad pick up when you cant hear the tapping with that pick up selected.
Posted on Feb 27, 2009
I have picked up a washburn lyon series electric guitar s/n 5062530 stamped on the neck plate what year is it and where is it made
It's probably 1995 Washburn Lyon WE3, the pickup configuration is two single coil pickups. It would be easier to tell if there was a photo available.
Dec 22, 2014 | Washburn Music
I just bought a new Fender deluxe roadhouse Stratocaster. I get almost no sound out of the neck pickup and no out of phase sound with the pickup switch at the fourth position. I have tried adjusting the...
Sounds like you're missing the guitar you paid for. Did you test the pick ups before you left the store or was it delivered? might be a bad weld. The wires might not be making full contact on to the connection of the pick up or the switch.
Dec 20, 2014 | Fender Music
Tone knob and switch info
the switch, has three positions. Typically forward or up will be your neck (or rythm) pick ups, only and will work with one volume knob(usually top right as your looking at guitar), and one tone knob ( top left as your looking at the guitar). when the switch is in the far right or all the way down position, that will be the saddle (or lead) pick-ups. And that works with only one volume knob(bottom right as your looking at the guitar) and the corresponding tone knob. when the switch is in the middle position, botjh volume knobs work and both tone knobs work. You've gotta kinda play around with them to find whatever sound yopur looking for. and tone knobs are very subtle in their changes. good luck
Aug 26, 2014 | Epiphone Sheraton II Guitar Electric...
I need to know how the five way switch works. I don't know which switch position turns on which pick ups.
In a guitar with 3 pickups a 5 way switch works like this. With the switch all the way forward( towards the tuning pegs) the pickup closest to the tuning pegs or end of the neck is completely on ( if your volume control is all the way on). The next position (moving away from the tuning pegs or neck) is a combination of the neck pickup and the middle pickup. The third position moving away from the neck is completely the middle pickup. The fourth position is a combination of the middle pickup and the bridge ( where the strings are fastened) and the fifth position is completely the bridge.
Nov 15, 2010 | Washburn Electric Guitars Modelno X11B
My Valley Arts Guitar (custom made) switcheroo system is stricken with static when I'm using the neck pick up (single coil). How can I fix it?
if the problem is only on the neck position it would seem that the switch or the pick up wiring is faulty. a little bit of WD40 on the selector switch will sort if the swtch is gone ...if you take the switch out and check the solder on the connections at the rear of the switch you may see the wire loose or solder point faulty.. just a dab with a solder iron should sort here.. you may need to resolder the connection.
Jul 20, 2010 | Epiphone Les Paul Studio Electric Guitar
Where can i find schematics for this guitar?
Depending on the pick up and switch configuration. You can find most of them at seymourduncan.com and look for your set up. Wether it's two or three pickups and so on. It's almost always standard setup regardless of the brand
Apr 07, 2010 | Washburn Wi14 Electric Guitar
I put a Seymour Duncan in my Washburn at the bridge. With volume on ten there is no output. If I back it off to 8, it works fine. Any ideas? It is an HSS with five way switch.
Here is their site:http://www.seymourduncan.com/ This site might also help:http://www.gmarts.org/index.php?go=230 You may need a different or new volume control.
Oct 19, 2009 | Washburn X10 Electric Guitar
Washburn D10BK has a background buzz i can not isolate! Constant
sound like a bad audio cord.  Are you too close to the amp and getting feedback?  Do you have the gain up to high?
Mar 27, 2009 | Washburn D10sbc Acoustic Guitar
Guitar from 1993 12 string returned for the 3 or 4 time.
I don't think this is a valid question for this site.
Mar 02, 2009 | Washburn D10sbc Acoustic Guitar
Music Logo
580 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Washburn Music Expert? Answer questions, earn points and help others
