Question about Goodman GMS90703BXA Heater
New goodman. heat will not keep up on cold nights. set on 72 but gets to only 64 in the morning.
  • 2 more comments
  • christi_schm Mar 08, 2009
    i set my thermostat at 74 and it kicks on then kicks off? i reset the circuit and it starts up then shuts off?????
  • Saulc Mar 19, 2009
    my furnace will start for afew minutes and shut off before reching the set temp
    my furnace will shut off before reching the set temp
  • jdthefixer May 11, 2010
    Goodman heater...to begin with, is the heater the right size for the job? You didn't say how much area you are trying to heat. I assume the heater is working properly.
    Second question (Christi) - You could have sevral issue. Is the gas on? Does the ignitor work? It should glow with heat when the heater starts. Also, check the flame sensor. If you have the skill, check that the ignitor is getting power. They will wear out after several years of use.
  • 10,865 Answers
All gas providers have a techie who will come out and check your system for you. They will tell you what the problem is and then you can fix it yourself, have them fix it, or have another technician fix it.
Posted on Apr 03, 2009
Goodman Model # GMC070-4b
is the thermostat set for heat and you have power going to the unit correct
Jun 05, 2017 | Goodman GMS90703BXA Heater
Blowing cold air when in heat mode Goodman model AR30-1
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 14, 2011 | Heating & Cooling
My furnace wont come on unless you turn it down then back up again. Its set at 72..but you have to turn it down then it will heat up..and you have to keep doing this unless you want to freeze!
The first thing I would do is change the thermostat and go with the least expensive manual heating cooling stat I could find and see if that helps,Thank you
Jan 03, 2011 | Goodman Heating & Cooling
Poor cooling. High bills when heating.
see if the lines the big one if it is verry cold or frosted let me know
Apr 08, 2010 | Goodman GPC1330H21A Air Conditioner
The thermostat is set at 72 and the heat hasn?t been kicking on!
yes it can what happens is that the house is loosing more heat than what your furnace or heat pump can produce.
Dec 16, 2008 | Weather King 12AJA6001AH Air Conditioner
Furnace clicks many times before igniting
sounds like it could use a new spark ignitor with new pilot assy. will probably die completely soon
Nov 26, 2008 | Goodman Heating & Cooling
Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Nov 21, 2008 | Goodman GMS90703BXA Heater
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Charging a central air conditioner in the cold weather
The copper tubing has cracked and water has leaked onto my roof. I have shut off the water valve that runs to the aircodtioner but cannot get someone over until the morning. It is a cold night. Will this be sufficient until I can get someone over in the morning. It's not that cold but there is a possible storm coming thru.
Oct 05, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GMS90703BXA Heater Logo
101 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
