Question about BenQ PB6100 Multimedia Projector
Can't access Menu
Projector is working just fine, except I can't access the Menu by either the menu button on the remote OR the menu button on the projector.
I have had the unit ceiling mounted with the image flipped, now want to use it "right side up", but the image is now upside down.
I need help to:
1 ) Get to the Menu OR
2) Return to factory settings if I can't ever get the Menu back
Thanks!
  • 1 more comment
  • Anonymous Mar 31, 2009
    Impossible to access menu.
  • clive pearson
    clive pearson May 11, 2010
    Hi I am Vortash ..does the remote do any functions on the machine please or does it do them all except the Menu Regards Vortash
  • Gary Mud
    Gary Mud Dec 14, 2013
    did u ome right with this as I am sitting with the same problem and I dont have a remote?
On the PB6100 you must have a input signal to access the menu.
Posted on Jul 18, 2009
I have the same problem, any ideas to solve.Thankyou
Posted on Jun 11, 2009
4 Suggested Answers
  • 269 Answers
SOURCE: ceiling mounted projector image upside down. how
download the manual from infocus
Posted on May 13, 2010
chris5563
  • 37 Answers
SOURCE: picture upside down b/c of ceiling mount
I assume you mean a VT491?
Manual link below:
http://www.necvisualsystems.com/cms/documents/UserManuals/RS232BaseMasterProjectors_rev3.0.30f.pdf
Posted on Nov 09, 2007
devocap
  • 201 Answers
SOURCE: I mounted the projector on the ceiling and need to flip the image
Hey there jpotto, You will need to use the installation menu. Inside you will find an option called image flip. Options are HV, H, V. Check it out. It specifically is used for ceiling mounts. Good Luck!
Posted on Feb 02, 2008
I forgot my password on my projector how to reset a password for dell 1201mp projector manually without using a remote control
  1. Access the projector with the administrator password. In case you never set or do not know this password, use the default administrator password 1234 or the 6-digit password which is provided on the Security Card, shipped with the projector.
  2. Once you access the projector menu, press the menu button. Press ? twice to go to the Management menu.
  3. Navigate to Security, and press ? to open the Security menu. If you are prompted for the administrator password, enter the password again.
  4. Navigate to User Password. Press ? to set a new password using the numeric keys on the remote control. Press Menu to confirm.
  5. You can select when the user will be prompted for the password: only when the power cable has been reconnected, or each time the projector is powered on. Press Menu to confirm.
http://delltechnicalsupportfromtechbuddies.blogspot.in/
May 29, 2017 | Dell Office Equipment & Supplies
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
Reset lamp timer
Aug 31, 2014 | LG Office Equipment & Supplies
HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
I cant unlock it
When you enable the Control Panel Lock function, you can lock all of the projector's buttons, or all of the buttons except the Ppower button. The remote control can still be used to operate the projector.
1. Press the Menu button, highlight the Settings menu, and press Enter.
2. Select Control Panel Lock and press the Enter button.
3. To disable the Control Panel Lock function, select Off in the Control Panel Lock menu.
4. Select Yes and press Enter to confirm the setting.
5. Press the Menu button to exit.
*- Or press and hold the Enter button on the projector's control panel for seven seconds. A message is displayed and the lock is released.
If you need a manual for your unit, goto here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=140128&prodoid=63085205
and click "Users Giude".
Jun 19, 2012 | Epson Powerlite S7 3lcd Video Projector,...
Trying to setup the Panasonic PTL 720U, accidentally turned off the control key to OFF in the menu and now cannot access Menu or another other options. How do I reset back to factory or so I can access the...
In order to set the CONTROL KEY to "ON" without
using the remote control unit, keep holding down
the ENTER button on the projector and press the
MENU button for more than 2 seconds. It will then
be turned ON.
Feb 12, 2011 | Panasonic PT L720U Multimedia Projector
Menu settings control inoperative.
I have the same projector and after I thought it is faulty, I finally solved the problem by putting a signal on the input. With out the signal the unit will only switch the bulb on and the menu wont be available.
Hope this help
Nov 21, 2007 | Acer PD116 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
1,187 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
