Question about Craftsman Air Tools & Compressors
I have a 33g craftsmans air compressor oilless
It fill up but wont shut off iv changed the relay now it wont fill up with air
Have a 26 gallon air compressor , changed regulator switch but it still wont shut off
Posted on Feb 25, 2009
    President:
  • 2,559 Answers
The pressure regulator switch is bad or in need of adjustment.
Posted on Feb 22, 2009
I have a 8gallon oilless that runs fine fills up like it should but after small workload for 30minutes or so it shuts down. Wont do anything till it cools off then it will fill back up. Any clues?
Sounds like a thermal overload on the motor. It will open and then have to cool down to close again. Check for it being dirty, or if it has a fan is it moving air? If you have it on an extension cord, the wire size may be too small. That is a pretty common problem with household equipment.
Jul 24, 2016 | Air Tools & Compressors
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
Takes too long to build up air
You don't give much information about your compressor. I have had several smaller "oilless", 1/4 though 6 HP compressors and my experience is that as they age, the rings wear and they are not good at compressing air. You can get a rebuild kit for the machine but I think you will find the cost is about 1/3 the price of a new compressor. This is not unique to the Craftsman brand, BTW.
Thanks for your question @ FixYa.com
Jul 10, 2011 | Craftsman Air Tools & Compressors
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
Aug 02, 2010 | Craftsman Air Tools & Compressors
Craftsman pro mod# 919167770 , oilless air
Check to be sure your drain valve under the tank is turned completely off first
Mar 12, 2010 | Air Tools & Compressors
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor pumps up to 40# and keeps running and wont shut off whats up replaced regulator assembly because knob was broken off but it didnt help the problem whats next ?
If this is an oilless compressor you most likely need to replace the piston. The piston in oilless compressors are made of softer metals and will become distorted over time partially losing seal in the cylinder. It will have enough of a seal to build some pressure but not enough to reach the cut-off point.
Jun 12, 2009 | Air Tools & Compressors
Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Dec 31, 2008 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
261 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
