Question about Krups Coffee Makers & Espresso Machines
Krups 7260 espresso machine error code
Error code 06, any idea what this is?
  • Anonymous Mar 09, 2009
    When I turn on my krups espresso machine, an error code n.6 appears on display. Any help?? thx
  • Anonymous May 06, 2009
    After the machine is switched on, just before every first use, it gives a 06 error.
    I have to swith off at the plug, wait 20 seconds, switch on again and it will work. ALL services are up to date including rinsing, cleaning, descaling and filter replacement.
    Please help solve the 06 error
5 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: how to use krups espresso machine
http://www.electrobest.com/krupinman.html
hers ther manauals on these thx nick rate me as fix ya thx
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: instructions for Krups Gusto espresso maker
I found the manual on an Amazon.com site for the Krups Gusto espresso maker (January 2009)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Posted on Jan 18, 2009
SOURCE: krups xp 7240 cofee machine
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Posted on Apr 27, 2009
  • 14 Answers
6
Pump in actuator down phase
The flow has not dropped (> 50ml/min)
after the actuator has been filled to the
maximum (80ml); there is a water
leakage and the actuator does not fill
Look for the leakage source:
hoses, actuator, priming valve?
Switch or distributor switch
control fault: incorrect detection
of cams  error in distributor
position in cylinder descent
phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
Error code 06 on Krups xpt 7240
Look for and remedy any internal leaks. If error 6 remains then expect to replace the distributor assembly.
Aug 20, 2014 | Krups XP Coffee Makers & Espresso Machines
Error code 06
Look for the leakage source:hoses, actuator, priming valve?
Switch or distributor switch control fault: incorrect detection of cams error in distributor position in cylinder descent phase.
drain ..)
2 picto boards
Jul 08, 2014 | Krups XP7260 Espresso Machine
Krups ea 8260 espresso maker error code 07
Error code 05 on my krups ea 8260. How to fix it?
Dec 24, 2012 | Krups Small Appliances Espresso Machine
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
Krups xp 7240 cofee machine says error code 06
- plug it back in
Good luck
Nov 01, 2008 | Krups Small Appliances Espresso Machine
Coffee Makers & Espresso Machines Logo
569 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Sergio M Perez
Mike Cairns
Mike Cairns
Ray Murphy
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
