Question about Indesit W 123 Front Load Washer
Indesit WD12 washer dryer with a leaking door seal
Looks like I need to replace the door seal on my Indesit WD12 washer dryer which has a small tear in it - Can anyone offer any advice on how to remove the existing seal and re-fit a new one - Are any specialist tools needed?
    Genius:
  • 1,075 Answers
This is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Posted on Feb 27, 2009
HI my ge adora washer is leaking and it looks like the rubber rim has 2 small u shaped tears about 3/8" in it what can I do,
You could try sealing the tears with silicon sealer, it might work, otherwise you will need to have a new rubber seal fitted.
Dec 16, 2010 | GE WSXH208A Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit WD12 door will not open once cycle has finsihed
I have the same problem and am now hoping you already have the solution ?!
Oct 09, 2009 | Washing Machines
Door will not open on my washer dryer wd12 model
Unplug machine take lid off and release the door interlock with fingers from inside by forcing catch open,you need new interlock can be supplied.
Oct 07, 2008 | Indesit W 123 Front Load Washer
Wd12 washer dryer(indesit)
hiya
firstly the rubber seal needs to come out, then i usually use an old socket and long extension bar and knock them out with a large hammer. fitting is the opposite of removal. a word of caution though if the centre of the bearing is hit it can damage them. you may be best searching the site for an engineer in your area as it could turn costly if you get it wrong.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 21, 2008 | Indesit W 123 Front Load Washer
Hotpoint Washer Dryer Leak in left corner
watch the drawer closely as it fills, on out side of machine it might be hard to see or else small hole in door seal also hard to find good luck luck close ire
Nov 27, 2007 | Hotpoint Aquarius WD640 Front Load...
WD12 Indesit washer/dryer
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: Timer- If your washing machine fills with water and begins agitating, but the timer won't advance. Then you need to replace the timer. Water supply problem- If water doesn't enter the machine when you start the process- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it doesn't get power, it seems that the problem is with the timer unit. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Mar 22, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
537 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
