ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775) Logo
Posted on Mar 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install camera - ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775)
Anonymous
Level 3:
  • ASUS Master 32,281 Answers
  • Posted on Mar 09, 2013
Anonymous
ASUS Master
Level 3:
Answers
32281
Questions
Helped
7912656
Points
102259
Install the WEBcam driver.
You can download the WEBcam and device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
tip
Installing Your Digital Camera Driver on Your Windows Computer To transfer...
Installing Your Digital Camera Driver on Your Windows Computer To transfer digital camera photos to your computer, you need to install the camera's driveron your computer. You can install a driver fairly easily on a Windowscomputer, and that driver lets you access your digital camera photos onyour computer. To install the driver:
91394.image1.jpgenlarge.gif Enlarge1Choose Start→Control Panel→Printers and Other Hardware→Scanners and Cameras→Add an Imaging Device.The Scanner and Camera Installation Wizard opens with the Welcome screen, as shown in this figure.
91396.image3.jpgenlarge.gif Enlarge2Connect your camera or card reader to your computer (placing your camera in Connect mode, if necessary). You can probably connect your camera by using a USB cable, as this figure shows.
91398.image5.jpgenlarge.gif Enlarge3Select Automatic Port Detection in the wizard (see figure), then click Next.The Camera Selection window opens.
91400.image7.jpgenlarge.gif Enlarge4Select your digital camera make and model in the Camera Manufacturer and Model lists; then click Next.If your camera or card reader isn't listed,install the driver from the disk that came with your device. Place thedisk in the appropriate drive and click the Have Disk button. Thewizard walks you through the process.
5Turn your connected camera on. Click Next.The Installation Wizard now asks you to name your device.
91402.image9.jpgenlarge.gif Enlarge6Type a name for your camera or device. Click Next.Choose a name that makes sense to you, or the camera's make and model.
7To complete the Windows installation process, click Finished.
on Sep 23, 2010 • Cameras
How do install my web cam
Dear first, make sure you follow the instructions from your camera manufacturer to ensure the proper installation of your camera.
This involves inserting the camera installation CD, being guided through a few steps for installation, and restarting your computer. Plugging in the camera's USB cord at the incorrect time during the camera software installation procedure can cause various problems.
To reinstall your webcam:
Uninstall any existing camera installations. Click "Start," "Settings," "Control Panel," and "Add/Remove Programs." From the list, choose your webcam software and click Remove.
Unplug the camera's USB cord from the computer.
Reboot your computer.
Insert your camera's setup/installation CD.
Follow the instructions described by the camera setup program, and plug in your camera only when prompted. This is usually done after restarting your computer.
Best regard.
I cant instal web camera in messenger
hi,
First, make sure you follow the instructions from your camera manufacturer to ensure the proper installation of your camera.
thanks,
P.S. rate our answers properly.
1helpful
How can Isettle to operatethe built in camera of VGN S210P -VISTA
You need to re-install the Camera Driver after installing the Vista Operating System in the Computer. Please try installing the WIndows XP Camera Driver and the Vista Camera Application in the Computer to resolve the issue.
You can download the Camera Driver here.
Please download and save the file in a folder in the Computer. Then, please open the folder where the file is saved and double click on it to begin the installation. After installation of the Driver, please restart the Computer for the settings to take the effect.
Then, please download and install the Vista Camera Application and Updates in the Computer.
Download the VAIO Camera Capture Utility
Download the VAIO Camera Capture Utility Update
Sony Camera Filter Driver Update
Please install the VAIO Camera Capture Utility and Updates in the same order. Please restart the Compuer after each installation for the settings to take the effect.
This should fix it..
Good luck..
Camera won't connect
I had the same problem. The driver did not install correctly. I then connected the camera without the memory card in, and the driver installed correctly. Subsequent connections of camera with memory card installed, worked fine.
How to download program to put pics from the camera on the computer
A digital camera driver allows the camera to communicate with a computer's operating system. Drivers can either be installed to your computer from the Nikon software CD or downloaded from "Digital camera driver download-Windows " Article.
Drivers are installed automatically when the Nikon software is installed. If you have previously installed Nikon software and you have the original CD and want to re-install digital camera drivers.
Installing Camera Drivers from the download.
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
1helpful
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
