Question about Acer X193W LCD Monitor
Acer Monitor Stand removal
How do I get this thing detached so I can use the articulating arm I've just bought?
    Problem Solver:
  • 5 Answers
On the rear of the monitor stand, just 1/2" above the word "Acer", is a rectangular button. push it in and pull the stand off . If you need to remove the rectangular tube, there are two snap on covers, one on each side of the tube. Pop them off and remove the screws underneath. That's it.
Posted on Mar 01, 2009
How to remove acer gd245hq monitor cover to replace screen
How To Remove Acer Lcd Stand - YouTube
? 0:40
Feb 10, 2011 - Uploaded by rakka1988 The "cowling" or plastic cover over the hinge where the stand enters the back of the monitor just LOOKS like it's part of the back of the monitor.
Reparar monitor ACER GD245HQ - YouTube
? 1:12
Jul 5, 2012 - Uploaded by C?sar ?vila
La mitad derecha del monitor no se ve?a, estaba negra, la otra mitad funcionaba bien. Cambi? todos los ...
Oct 16, 2015 | Acer Computers & Internet
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
I just bought an acer S202HL LCD monitor and I came with no instructions Just pieces. I need to find out how to attach the stand to the monitor.
Free Acer S202HL manuals!
Problems with Acer S202HL?
Ask a new Acer S202HL question
i cant get a closer look at the diagram
how many screws did it come with
Ensure that the base is locked onto the monitor stand arm
hope this helps you
Nov 28, 2011 | Acer S202HL LCD Monitor
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
I'm attempting to repack my AL2216W LCD Monitor into the original box. When I slide the two foam protectors on the ends, it won't fit into the box. The stand is in the way no matter how I position the foam...
Of course there is a trick to this. Remove the stand by pushing gently on the clip at the bottom. I usually turn it upside down to do this. Then lay the stand on top side of the foam.
Please rate this answer as the only thing I get for answers is a rating.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
I need to detach the stand of HP 1950 TFT monitor screen and then mounth the monitor on a special stand. How can detach the monitor from the hinge seen below the screen.
Removing the base is covered in the manual. You can download a copy from HP here.
If you don't like clicking a link the full URL is
If I have helped you, please take a moment to rate this solution. Thanks for asking here!
Mar 18, 2009 | HP w19 19" LCD Monitor
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Acer Monitor, Model No. X223W -- I can't get the arm of the back of the monitor (the thing you stick the base into) in order to mount on a multiple monitor stand (quad)... Spoke with Acer Tech Suppoort and...
i have the same problem with the AL1717. After hours figuring it out, i found the solution.. if you slide off the cover holding the back arm, you will expose the screws holding the arm which you can screw off to take off the back arm....
the cover can easily slide off as it is only 'clicked' into place.... gently put your fingers on the cover apply some pressure to slide it out...
Dec 19, 2008 | Acer AL1717 17" LCD Monitor
Disassembly for shipping
As per page 4 of the User's Manual from Acer:
Detaching the Monitor
If you need to repackage the monitor, please separate the monitor and base, and restore them to
the carton. To detach the monitor:
1. Unplug the AC power cord to make sure the power is off.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base and put them into carton.
Jun 19, 2008 | Acer AL1716B 17" LCD Monitor
Acer X193W LCD Monitor Logo
1,941 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
