Question about Singer Quantum 7322 De'cor Mechanical Sewing Machine
The bobbin thread won't catch and when it does it is knotted
It is a new machine for me....a gift from my daughters to reconnect me with sewing again....However, when I threaded the bobbin for the first time, the thread knotted under the fabric....I am obviously threading the bobbin in the bobbin case incorrectly...I tried for many hours unsuccessfully to thread the bobbin correctly...Please help me to thread the bobbin in the machine so that I can sew with it....
SOURCE: tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Posted on May 09, 2007
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 3 Answers
SOURCE: Singer 4623 bobbin thread won't catch
Here's one, have my 3rd singer (the only thing Simple was me for buying it)
The upper thread just goes around the pin that the bobbin sits around.
The vendor was gracious in exchanigng twice, by the way,
machine #1 sewed for 92 days, singer's warranty is 90 days, & only for parts,
they generally say it's a timimg issue, (all labor, no parts, )
& oh,
there's a deductible
I guess the solution is don't buy a singer
they used to be very reputable
but, chose mass production
Posted on Apr 18, 2010
  • 18 Answers
SOURCE: singer 5525 sewing machine knots
You can go here, search 5525, and download or purchase an instruction manual for your machine, if you have misplaced the one that came with it. It looks like there are some available as downloadable pdfs for free and some physical ones for $15. https://www.singerco.com/accessories/manuals.html
Also, Singer has just installed new Q&A features on their website. You can go here: http://new.singerco.com/products and look for your particular model or machine category. At the bottom of the product page, you can post Questions for singer experts and other community members to answer!
Posted on Jul 22, 2010
  • 1788 Answers
SOURCE: my bobbin thread keeps getting knotted up when I
Your top threading is not right. Rethread, check your tension on your thread by pulling on the thread with the presser foot up, it should be smooth. Now, lower the presser foot and try to pull it, it should barely move. If, either is not happening, you are not threaded right, it depends on having the right tension.
Posted on Oct 15, 2010
Testimonial: "Thank you so much! I tried this and it worked perfectly!!"
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
This machine came with a very limited Manuel. The bobbin thread is knotting up and not catching as it should. I've re threaded several times removed and reinserted the bobbin, but can't seem to find the...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Janome SEW MINI Mechanical Sewing Machine
I have a brother sewing machine. i threaded and have rethreaded and threaded the bobbin over and over. it will not move the fabric and botton thread will not catch onto top. what am i doing wrong?
Brother machines are usually a very good brand. Sounds like you are having a small problem with threading..........I know how frustrating that can be!
Start over....totally from the beginning. First, clean the machine of all dust, I use a small paint brush to remove lint from the bobbin case area. Oil the machine. Remove all the thread from the machine, use a different bobbin and rewind it with new thread. Make sure the bobbin thread is the same as the thread you use to thread the upper needle with. Use a new needle that is the appropriate size for your sewing project. Check to make sure the feed dog is moving when you turn the wheel that raises the needle up and down. New needle, new bobbin, new thread......before you place the fabric under the presser foot (and with the presser foot raised), turn the wheel one complete rotation to allow the upper needle thread to catch the bobbin thread. Gently pull both threads out towards the back of the machine, making sure the bobbin thread is now coming up through the little hole in the feed dog plate. Place fabric under the presser foot, lower presser foot and as you slowly start to sew, make sure you have the bobbin thread pulled with slight tension out from the back of the needle. This will take up any slack in the bobbin thread and keep it from making a knotted mess. Good luck, I hope this helps.
Feb 13, 2011 | Sewing Machines
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
May 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer Quantum 7322 De'cor Mechanical Sewing Machine Logo
44 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
