Ups disconnect get a intermintent ups disconnect then reconnect, how can i fix this
    New Friend:
  • 37 Answers
It could be the relay is faulty repalce with a new one
Posted on Mar 31, 2009
Intermintent pinging on accerlation
Intermintent pinging Bruce, Try a couple tanks of better grade fuel (premium) to see if pinging reduces/ or goes away.
Mar 29, 2016 | Cars & Trucks
Replaced intake manifold in 1999 lincoln towncar now intermintent low rpm missing
My first guess would be a vac leak around one of the gaskets, or a hose is disconnected. A leaking gasket could change with the engine temp.
Jul 06, 2012 | 1999 Lincoln Town Car
How do I fix the constant flickering of the screen?
Take the lcd assembly apart, and disconnect and reconnect the ribbon cable on the back of the lcd. Also disconnect and reconnect the other end of that cable. If that doesn't fix it, disconnect and reconnect both cables that go to the inverter board (it's the small circuit board inside the lcd assembly- example in picture below). If still no good, then you probably need a new inverter board. Call HP and get a phone number for one of their parts suppliers. Inverter boards are cheap ($10-$20). Even if it doesn't fix it, it doesn't cost much to try. If still no good, then take it to a service shop.
Hope this helps!
Joe
Mar 22, 2012 | HEWLETT-PACKARD HP Pavilion G61b70us...
Hi - I have a HP Officejet Pro K5400 printer. That printer & my Dell Optiplex GX620 was left on during a 2 week office absence. When I returned the blue ink cartridge indicator light was blinking and...
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
May 20, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
I changed the ink of my printer and now it wont print anything just keeps flashing a red light. Ive tried turning the computer on and off but nothing is fixing it. Please help
Please perform the steps below and check..
If the issue still persists please get back to me with the Printer name and model number
May 18, 2010 | Office Equipment & Supplies
Intermintent rough idolling and hesitating
Check for codes
May have a bad Coil
May 01, 2010 | 2005 GMC Savana
Intermintent cruise contol on 2007 ion coupe 2.4 not red line. I've had it to the dealer several times, and it seems to work for them thats Bull### what else can I do to fix this? Thanks
My 2007 Ion 2.2L sedan has the same issue. Every now and then when I am driving, the Cruise Control fails to engage. If I turn the car off, re-crank it, it works fine. Dealer cannot find the issue and it only happens about once a month. No bad computer codes or anything, just annoying.
Mar 25, 2010 | 2007 Saturn ION-2 Quad Coupe
Flashes on and off,intermintent will turn on all
This is most likely a connector fault to the radio. Particularly check any inline fuse that may be fitted.
Remove the radio from it's mountings and check all connectors. Check all wires into the connectors that they are not loose.
Keep connected while you turn the radio on with it out of its fixed position. You can sometimes find wiring faults by moving wires while connected.
This is most likely to be the fault.
Oct 01, 2009 | 2002 Chrysler PT Cruiser
Door chime goes off while driving.
IF YOU KNOW WHICH DOOR IS CAUSING THE PROBLEM THERE SHOULD BE A BUTTON SWITCH FOR THAT DOOR SOME SWITCHES WILL POP OUT OTHERS SCREW OUT REMOVE BUTTON SWITCH AND DISCONNECT WIRE TAPE WIRE ENDS REAL GOOD AND PUSH BACK INTO WHOLE WHERE SWITCH WAS AT PROBLEM SHOULD BE SOLVED YOU CAN BUY AFTER MARKET SWITCHES TO REPLACE THE ONE THAT IS BAD
Aug 10, 2009 | 2003 Volkswagen Jetta TDI
Computers & Internet Logo
228 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
