Question about Frigidaire Refrigerators
Not cooling or freezing, all lights work in the unit
There aren't any noises coming from the unit
  • Frigidaire Master
  • 3,361 Answers
Do you hear a clicking noise approximately every 2 minutes from the compressor area?
If so, replace the start relay on the compressor.
If no, tap on the on/off thermostat and see if it cimes on.
If yes, replace the thermostat.
Posted on Feb 22, 2009
Not freezing
This unit has issues with the evap fan freezing up. If you heard a grinding noise coming from freezer, fan froze up. Unplug unit, open freezer door and if you have a box fan, point it into freezer for a couple hours. Be sure to unplug fridge
Aug 18, 2012 | LG LSC26905TT Side by Side Refrigerator
I have a Kichenaid Refirigerator Model# KSRB22FKBL04 it is not cooling or freezing. Light is on, there also a running sound and sometimes no sound but run again but still not cooling or freezing. I need a...
Are both fans running, in freezer and in back? Remove rear panel on back of unit. Check to see if noise is coming from compressor area. If it is you either have a bad start device or a bad compressor. Use your model number to look up and order a new start device here, the cheaper of the two. est. cost at $25-45
Mar 24, 2011 | KitchenAid KSRS25CNBT / KSRS25CNLK /...
I have a Frigidaire cooling and heating unit. Last night we had freezing rain and ice. I heard a weird noise coming from the unit then smelled a burning smell. I turned the unit off. The top vent...
Sounds like the motor burned up when the ice blocked the air which it was not able to cool the motor it will need to be replaced. (the motor)
Jan 29, 2010 | Heating & Cooling
Unit has stopped cooling and freezing also making gurgling noise
it sounds like the frezzer fan stoped and what your hereing is the freon coming in
Apr 17, 2009 | Refrigerators
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
Dec 13, 2007 | Microsoft Xbox 360 Console
As you've said that started it with freezing up, either the unit has a leak then the refrigerant escapes or restricted system.
In this problem you need a qualified technician to repair the leak or reprocess the system and flush out the restricted system or repair kink pipe that cause restriction.
Oct 22, 2007 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
