Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I have had my machine for almost 2 yrs. with no problem but all of a sudden, the needle is hitting the metal casing for the bobbin. I thought I had a bent needle so changed it using the singer needles enclosed with my machine. I took of the plate to see where it was hitting and cleaned the machine as I always do. No matter what needle or what foot I use (I have the quilting walking foot on now) it still hits. I have the needle in straight and correct. Please help ..lots of projects to get done!! Smiley in Wisconsin
  • sksmiley61 Feb 22, 2009
    This is not the problem ... I was not embroidering when this problem occured. I was simply wanting to sew. I had changed from the normal foot to my walking foot. So thanks, but that is not the problem.
    President:
  • 1,073 Answers
Your machine need to get adjusted, thats all. But you cant do that by youself, you need someone who knows how to do it. Take it to a shop that sells sewingmachines, they can help you and its not expensive.
If u using your sewingmachine a lot, a good advise is the get it lubricate and adjusted once a year.
Get it adjust and you will be fine
Nic
Posted on Feb 22, 2009
  • 15,935 Answers
This is most likely a timing issue.
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Feb 22, 2009
    CLICK HERE to see instructions on how to set timing.
    Please rate the Expert which gave you the best information.
    Thank you.
    President:
  • 2,110 Answers
Did you have the hoop on before you turned on the machine? if so.take off the hoop and turn off the machine and wait 30 seconds turn it on and wait for the carriage to move, then attach your hoop.
    Brigadier General:
  • 3,614 Answers
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
  • micromaster
    micromaster Feb 22, 2009
    if the above info has done. let us know again here.
    Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Please check the Bobbin Winder.
If the Bobbin Winder shaft is moved to the right position (bobbin winding mode)
  • Rylee Smith
    Rylee Smith Feb 22, 2009
    Also check the Needle clamp screw, it could be loose.
    Presser foot is not correct, one Presser foot is loose .Check presser foot and Reset the presser foot.
    Please revert for any clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Try loosining the gear you installed and moving the hook in such a position that at the needles lowest point it will form a loop with the thread as it starts back up and the point of the hook will catch that loop and bring the threads around and back up through the needle plate and tighten the gear back up. You may have to do this several times before getting it just right.
    Thanks
    Rylee
The needle in My Juki Skyline S5 hits the metal ring in the bobbin casing. This just started suddenly while I was sewing.
the needle /hook timing has slipped or the needle is not installed properpy
take it in and have it readjusted
Dec 07, 2017 | Juki Sewing Machines
I have a ULT2002D Brother sewing machine that keeps catching the thread. From the needle and winds around the bobbin causing a jam. What Can I do about this and can I fix it myself
Sounds like there is a hook of metal either on the needle or the bobbin case (sometimes happens when trying to sew something very very thick and the needle bends slightly and hits the bobbin case.). Suggest changing needle 1st, if this is not the problem, take out bobbin case and look and feel with fingers, if there is a mark where the needle has hit just use your own steel nail file and file the area very gently to remove the bur. Good luck!
Oct 11, 2017 | Brother Sewing Machines
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Needle hits bobbin case
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
May 20, 2010 | Sewing Machines
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle is hitting the round , turning case that revolves around the bobbin
It sounds like your timing is off because what you're describing is exactly what happened to me last summer. I took it to a sewing machine repair shop and they repaired the problems, gave it a nice cleaning and it was like new when it came home. But it took two weeks (not a lot of repair shops around here) and that was torture as it's my only machine!!! :)
Aug 17, 2008 | Euro-Pro 9120 Computerized Sewing Machine
Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Jun 30, 2008 | Singer 7442 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
78 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
