Question about Home
Jacuzzi tub makes noise but jets wont work - Home
  • 2 more comments
  • Anonymous Mar 16, 2009
    how do i fix it? I think it sounds as if the motor is runing but the fan is stuck. how do i gett to the fan to spin it and un stick it? This unit started working right the first time but when i turned it off then back on the noise started and the jets did not.
  • the1bamagirl
    the1bamagirl Apr 25, 2009
    I just bought a brand new house, and the whirlpool tub won't work! When I press the on button- the motor makes a normal humming sound, but the jets won't work. I read some other threads and tried all the simple things like twisting the jet covers, and checking the intake but I've had no luck. I've finally taken off the front cover of my tub, and I've discovered that the motor itself isn't sitting on the floor properly! It's wedged between the the wall and one of the hoses from the jets- but not enough to crimp it or block it's flow. Is it possible that the motor is sitting too high above the flow of water? And should I try to make it (the motor) sit properly?
  • Arthur Bayne May 11, 2010
    Is it the normal noise you are used to hearing (typical pump humm) or louder then normal / grinding / rattling?
    Can you observe if the pump shaft is turning?
    Is there anything obstructing the suction port?
  • Anonymous Mar 12, 2014
    The jets on our white LM 65519 jacuzzi tub are getting black after several years of use. How should I clean them? Do I have to take them apart?
  • 125 Answers
Sounds like maybe the impeller is just spinning on the shaft of the motor.
Posted on Feb 24, 2009
5 Suggested Answers
  • 15 Answers
SOURCE: my bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Posted on Oct 04, 2009
  • 7 Answers
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Posted on Dec 12, 2008
  • 41 Answers
SOURCE: We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Posted on Mar 03, 2010
packrat1948
  • 528 Answers
SOURCE: I have a jacuzzi tub with the whirlpool WOW motor.
Open the access panel and see if the motor is working or just trying to work. Sounds like it may need lubrication.
Posted on Feb 05, 2011
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Dec 04, 2008 | Home
Home Logo
2,005 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
