Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero fridge doesnt turn off
I turn it off manually (press the off button) and then turn it back on, the motor is quiet. After some time (10 minutes or so)- the motor turns on - and stays on.
  • ratalman Feb 22, 2009
    Is a bad thermostat control an easy fix. Can it be done oneself or does it require a repairman.
    Thanks for the info jumptrout51
  • ratalman Feb 24, 2009
    Does anyone know if a thermostat control replacement on a Sub Zero Fridge 650/Zero bottom freezer is an easy replacement or does it require a repairman?
  • Sub-Zero Master
  • 3,361 Answers
If your temperatures are OK, then you have a bad thermostat control.
Posted on Feb 22, 2009
My sub zero 600 series has no light in fridge nor on control panel
There will be two switches per compartment, one is the fan switch, the other is for the lights... Remove the top compartment vent panel, the switches will be accessed from above... remove the wires and push them down into the fridge... you can test them by setting a meter to "continuity" test and pressing the paddle of the switch to see if it lets current through.
SUB-ZERO machines are more serial number dependent when ordering parts... http://www.midwestdistributing.com/Store/OpenPages/ManualPage.aspx?PageTitle=MANUALS
Aug 20, 2016 | Sub-Zero 632 / S
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
Jun 02, 2012 | Sub-Zero 561 / F
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
1983 sub zero 241rfd with extensive ice on fridge coils and frost back of fridge drawers. Is this fridge frost free or do we need to defrost? We have defrosted by turning off fridge, but wondering what the...
sounds like a thermostat and a timer to me
start off with a thermostat if that doesnt work buy a timer
it's a bit expensive like 100.00 buy if you like the fridge or cant afford a new 1
thermo $10- $30
timer 30-70 try to buy recycled parts that are tested there cheeper
Jul 27, 2009 | Refrigerators
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 700tc/fan runs but no compressor
A check of your breaker is in order. From your description the breaker could be week. If so the breaker my not cut off all the way and still allow enough power through to opperate the fan but not the added load of the compressor.
I have seen this a few times and it always confuses me too. Check the circuit by maybe moving the circuit on the breaker to a different one then retry it and see if the problem is gone. If it is then replace the breaker if not then its time to use a volt meter or call a repair person. And this is because there are a lot of what ifs that have to be covered to get to the root of the problem if this is not the trouble..
Please lket me know whow this works out. Rate me as high as you can and thank you for using fixya.
Apr 28, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
202 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
