Question about Electrolux Vacuums
AAAArrggghhhh my vacuum makes a weird noise and spits out sparks
My vacuum makes a weird noise and spits out sparks
  • glenn_collie Feb 25, 2009
    out of the motor housing
  • 3 Answers
Out of the vacuum housing or base?
Posted on Feb 22, 2009
  • adseverance Feb 25, 2009
    Take off the vacuum housing. Unscrew the base and remove the top cover. If it's a 14" it will have more M5 screws on the bottom
    of the base. You must remove the brush cover strip on the side
    of the base first.
    If you can, take a digital picture of the inside of the base.
    I'll go from there. We fix about 10 Versamatic's per week
    at Dartmouth College. We are responsible for 220 on
    campus.
    Sounds like the brush motor. So look for any charring
    around the motor.
There are sparks coming from the underside of my oreck xl vacuum.
You probably need to take that in and have it serviced at a repair shop. They can check the motor to see if it needs to be replaced or just cleaned. The noise could be bad bearings or a fan problem as well.
Feb 21, 2013 | Oreck Vacuums
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I have a loud noise coming from the vacuum. also doesn't pick up
Check underneath, behind the roller where the opening to the hose is. I had the same problem that was caused by a Lego lodged in the opening and when it was removed, the vacuum worked like a charm.
Jun 16, 2009 | Kenmore Progressive Bagless Upright with...
The brush on my Dyson DC-14 wont spin
hello, have you checked to make sure you have nothing wraped around the brushes ? also it sounds like your belt needs to be replaced.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Jan 08, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Vacum will not pick up
Due to the way carpets are made - new carpets sometimes have a lot of loose fiber. This is NORMAL and it may take 3-5 times to vacuum the carpet till it goes back to normal. Spitting out fuzz balls is a bit weird. Make sure you have the belt installed right - see video on www.goodvac.com. but the fact that belts keep breaking I am assuming that you have them installed right. Give it a few more belts and if the problem presists - let me know.
Rocky
Dec 26, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Weird noise
Check to make sure that the hose and the inlet down by the brush roll are open and not clogged. It could be a bad bearing in the motor, if so, you are looking at replacing the motor.
Dec 10, 2007 | Vacuums
Vacuums Logo
129 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
