Question about HP Photosmart E327 Digital Camera
Photos wiped from e327 memory card
I have twice taken photos with my HPe327and upon plugging the usb into my camerathe photos were wiped from my camera's sdmemory card. What is causing it and can I recover the photos?
  • 36 Answers
Do you safely remove your memory card when you remove it?
if not then i highly recommend you should.
Also try the memory card on another computer and see if the photos are there.
Posted on Feb 22, 2009
What format i need to download photos
Depending upon the settings of image quality, most likely the photos are stored in jpg file format.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 01, 2013 | Cameras
Unable to view photos i have taken, Screen says Read Error
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 16, 2012 | Fuji FinePix Cameras
The computer cant see any photos when i try and download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 06, 2010 | HP Photosmart E327 Digital Camera
When I plug in the usb cable, my computer says "unrecognise USB device was pluged"...how to make it recogniseable?
Aug 17, 2010 | HP Photosmart E327 Digital Camera
I HAVE THIS CAMERA AND HAVE MISPLACED THE INSTRUCTIONS ON HOW TO DOWNLOAD PICS. CAN YOU ASSIST?
Jan 02, 2010 | HP Photosmart E327 Digital Camera
My download disc works with xp operating system. I now have vista home premium how can I get a download for my camera
You don't need any additional software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
May 05, 2009 | HP Photosmart E327 Digital Camera
Can not connect to USB Port - Error Message (Warning - Drive G:\ containing photos in library has been disconnected. Please reconnect drive and click retry.) Never have gotten this message after hun
Try unplugging a few other things like USB hubs before plugging in the camera. If this does not work, please advise what other messages you get when attempting to connect the camera.
If you are PC savvy, check out device manager in control panel to see if this gives you any more indication as to what the problem is.
Apr 30, 2009 | HP Photosmart E327 Digital Camera
HP E327 would not download pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 20, 2009 | HP Photosmart E327 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Photosmart E327 digital camera
I had to buy the memory card for mine when I got it and it holds about 160 images.
Feb 16, 2008 | HP Photosmart E327 Digital Camera
HP Photosmart E327 Digital Camera Logo
64 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
