Question about Spark Plugs BR4HS Plug 10/BX #3322
Hi i changed my ht leads on a ford focus 1999 1.6 zetec s did'nt relise there is a firing order could any one help
  • 653 Answers
The typical firing order on a four cylinder engine is 1-3-4-2.
Posted on Feb 22, 2009
  • 15,935 Answers
The order is 1,3,4,2.
1 is the one furthest away from the coil pack.
Thanks for using FixYa - a FixYa rating is appreciated!!
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2004 ford focus no spark changed ht leads coil pack and crank sensor but still no spark
could be on the LOW tension side of the ign pack check any wiring leading to ign pack
Mar 26, 2014 | 2001 Ford Taurus
ECU relearn ford focus
call dealer service and see if its a reprogramming issue..personally I dont have a clue..
Dec 14, 2013 | 2002 Ford Focus
Hi, I have a problem starting my Ford Focus Zetec 1.6 from cold or in wet weather ive replaced the HT leads but problem is still there the engine light is now staying on, please help!
nick,the best way to sort out your car is to get a diagnostic done(a main dealer has the kit,as does kwick fit)that way you can decide if you want to do the job or pay them to do it.(its too expensive for us to buy the computer)ask for a full diagnostic,not just the codes.
Nov 27, 2010 | 2003 Ford Focus
Firing sequence for 1999 ford explorer ...(changing spark plugs)?
if you are not sure what goes where with the ht leads why not tie a lable to each one or only change one at a time......say left bank then right bank....you do not have to take all the leads off to change plugs.
Jul 12, 2010 | 1999 Ford Explorer
How to change the spark plugs on a 1.6 zetec ford
get a plug spanner (more a socket than a spanner) and after removing the plug lead, use the spanner to remove the plug. Do one at a time so you dont get the leads mixed up or it will not start.
Nov 23, 2009 | 2002 Ford SVT Focus
Ford focus i.6 zetec 02 plate: engine management light came on and car runs as if runnin out of petrol,n like there a block in the air filter?please help
check the wiring to the plug conector on the coil pack as the wires usually brake.
if they are fine check the coil pack and ht leads as they are known for going down too.
please let me know if this helps
cheers
big mike :)
Nov 01, 2009 | 2001 Ford Focus
Ford focus zetec 1.6 auto, Misfiring and no power
It's normal for the cat to get hot - given they've replaced everything (just about) that could cause your problem - they have not looked at the injectors and O2 sensors. If you had something burning in the engine bay it was most likely electrical and you should look for burnt wires. You probably have a short in the ignition system or fuel injector wire harness. It's nearly impossible to diag a problem like this without having the car first hand. It must be throwing check engine light codes. Get the codes and post them. Also try a different shop at this point.
Aug 07, 2009 | 2002 Ford SVT Focus
Miss firing
here is a list of possible causes.
1- worn,faulty or incorrect plug gaps
2- faulty HT leads
3- engine management fault.
4- vacuum leak on inlet manifold or hoses
5- incorrect valve clearances
6- faulty hydraulic tappets
7- uneven or low cylinder compressions
8- disconnected or leaking crank case ventilation hoses
Apr 28, 2009 | Ford Festiva Cars & Trucks
Escort 1998 1.8 zetec mis firing
Hello, did you try changing your coil pack
Feb 07, 2009 | 1996 Ford Escort 4 Door
try using a gauge to measure fuel delivery pressure but this tool may only be available to the dealer or a big garage,best advice in a case like this is put car in dealers as you cant read the the ECU readings as the OBD II connector cable doesnt have manufacturers pin connections.Have a funny feeling this problem is a concoction of different faults,but try checking gauze filter on bottom of pump in the fuel tank or for porosity on the flexible connections that connect the plastic fuel lines to the unit on the tank .
Oct 04, 2008 | 1998 Ford Escort
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
477 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
Zachary Reed
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
