Question about Alert Radio Communications
I'm a new owner of a 2003 Heritage softail
I need to know how to drain the oil and tranny fluid and where you fill the tranny at and what weight and type of fluids are best to use. I would appriciate any help. E-Mail me at blea885@aol.com Thanks Todd
    Problem Solver:
  • 19 Answers
You will need either the HD oil filter wrench (HD-44067), which fits over the end of oil filter Harley-Davidson SuperPremium5 Oil Filter 63731-99A and allows you to remove filter with a ratchet and extension, or a strap type oil filter wrench purchased at an autoparts store. I use the strap type generic wrench. The HD wrench, actually a hex cap to fit over end of filter, would be a worthwhile investment. There is very very limited side access to filter on bike neccesitating one of these tools. Pan drain plug on same side, to front of pan at corner. Drain oil, remove filter, wipe off filter mount, fill new filter with fresh oil and install, pour in 5 quarts total using a flexible neck funnel, and your done. It takes 5 quarts total including what you use to fill new filter. SAE 20W50 or SAE 60 grade is appropriate for ambient temperatures above 80 deg to over 100 deg F. BE VERY CAREFUL WITH "O" RING !!!!!
Tranny:
This one is tricky get yourself a service manual. "O" rings are a pain man! train plug should be line up with dip stick.
Posted on Feb 24, 2009
Where is oil drain plug 2003 heritage softail?
Hi Anonymous, it is on the bottom of the frame tube right hand side all the way in the rear. Have nice day.
Apr 18, 2013 | 2004 Harley Davidson FLSTC - FLSTCI...
2008 FLSTC WHERES THE DRAIN PLUG FOR 6-SPEED TRANNY OIL ??
Hmm, that's a good since I haven't seen a six speed up close yet. I work with the older bikes. But, one the five speed, the drain on the Softail was a small pipe plug that uses a Torx wrench. It is located just below the right side chrome cover where the clutch cable goes in. The drain will be there or underneath the tranny but more than likely where it has been on the five speed.
Good Luck
Steve
Aug 14, 2010 | 2000 Harley Davidson FLSTC Heritage...
Where is the oil drain on the 2003 Heritage Softail Classic?
on the right side of the bike where the swing arm and frame meet look for a 5/8" head drain plug pointing straight down that is your drain for the engine oil.
May 11, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
No expert on newer Hogs but try this.If tank is replica of wrap-around type look on flat right-rear bottom over rear pipe.Just a flat bolt-head.Yep,it's messy,cover the pipe.Like I said,no expert. Follow bottom most oil line from oil pump back to oil tank. Maybe it "t's" off under frame into line that drops down toward ground. You could get a catch pan under there.I vote for the nut on tank.Wrap around,you know, the battery is in it.
Mar 19, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
I just changed oil in softail and now it is pouring oil from breather what is going on
Was this your first time changing the oil?
Sounds like you may have drained the tranny and
over-filled the motor......
Did you have a book/ manual?
Harry
Sep 11, 2009 | 2000 Harley Davidson FLSTC Heritage...
97 Softail custom fluid change
here goes oil bag takes 2.8 with new filter Harley says 3 but that will overfill. Primary takes Harley Primary and trannie Oil primary takes 32 oz or one bottle...trannie takes between 20 and 24 oz. I always put in 20 oz and thqt will work fine...make sure your bike is up to operating temp when draining your oil so it all flows.
Jul 05, 2009 | Harley Davidson FXST Softail Standard...
Where is drain plug on a 2005 Harely Davidson Heritage Classic?
its on the right side of the bike at the back on the frame u will see a hose connected to the swing arm look under and u will see a drain plug do not pull the plug between the shocks its the tranny
Jun 28, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
Harley davidson flstc heritage softail 1997
The fork oil is a very specific job needing a manual and a special tool, I don't want to insult anyones mechanical knowledge but if you have never done it before, best to take somewhere else. Engine oil on the other hand is easy, the drain tube to any softail is on the right side by where the frame meets the swing arm, has somekind of plug in it. Start and run bike for a little while, long enough to get it warm but not hot. Remove fill plug and then remove plug in drain line. Using a peice of cardboard or something put in between filter and frame , directing the oil to your drain pan instead of where ever it goes. Put 1 qt oil back in (after everything is reinstalled) start the bike and make sure the oil light goes out, when it does shut bike off and fill to the point that when it is standing upright you get a little oil on the tip of your finger, over filling may result in loss of oil cap from pressure (been there)
Jun 15, 2009 | Harley Davidson FLSTC Heritage Classic...
No service manual-need fluid capacities
20-24 oz. in tranny, 32 oz. in primary, 3-31/2 qts. in engine. I use 20\50 in engine and primary. and 70/100 in tranny. I use syn. amsoil. Good luck
Mar 25, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
Radio Communications Logo
91 people viewed this question
Top Alert Radio Communications Experts
xxxxxx xxx
eradiostore
eradiostore
Eric Sutherland
Are you an Alert Radio Communication Expert? Answer questions, earn points and help others
