Question about Samsung CLP 300 Laser Printer
A spot on all my printing.
It looks like a clear label like the ones I use for X-mas because I took out the back and found three labels in different places. I thought by pulling them out it would clear the problem. Still remains. Put it back together and the message is "blocked at the paper exit". It looks to me as if the glue on the label melted onto something hot. Printer only less than two years, great machine. If you have an idea I'd like to hear it. I can take it apart ably but didn't want to go any further.
  • confra Feb 22, 2009
    Thanx, I guess I was right. If it needs to be replaced, is it worth the money or just replace the printer. When it worked it was great, but someone (Samsung) should have warned users about the glue. Do you think it's something I can do, or is it too internal. Again thanks for your help. -f-
  • JDTec
    JDTec May 11, 2010
    you may have glue on the fuser, in which case it needs to be replaced. The fuser is the unit that fuses the toner to the paper, hence it gets very hot. Glue and heat do not mix well together.
  • Samsung Master
  • 4,338 Answers
I could not find the service manual from it but I saw (on an Italian website) that the fuser is accessed by openiing the rear door, It usually held in by 2 screws. Make sure that the unit is off and cold. Don't want you to get burned by a hot fuser.
Looks like the fuser is about $100 and up:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 23, 2009
We are using Clear Labels (Width - 2.5 & Height - 3.5) With Gaps and We are only able to print one label, and then it shows Paper Jam Error Message. Please let us know what could be the Problem here,...
The printer cannot do the difference.
Have your supplier to print on the reverse side a dark color spot coresponding to the size of your label and use the transmissive cell detection
Aug 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
When we print labels, it skips one each time. We have been on the phone with Datamax three times and all systems appear normal. When we do a test of the Datamax it DOES NOT skip[ any labels but as soon...
Hello, Nancy.
It's clearly your application, since a test print appears normal and all systems appear normal. Is it possible to reinstall your application ?
Hope this helps.
Mar 06, 2011 | Datamax DMX-I-4208 Label Printer
The machine prints about 12 labels and then prints about 25 empty ones, prints 12 and the pattern repeats. Restarted the computer three times and restarted the printer five times, nothing helped.
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Feb 18, 2011 | Datamax DMX-I-4208 Label Printer
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
I am trying to print using Avery 8663 clear mailing labels using my HP Photosmart 3310 all in one. The printer keeps shooting out the paper with the message "please remove the paper and re-insert it with...
Does it still print on plain paper? Check to see if you are missing one or more labels as they may have come off and onto a roller or other part. I've found that label sheets with any labels removed prior to printing are always prone to loosing labels in the process of traveling through the printer.
Dec 07, 2008 | HP Photosmart 3310 Printer
Photosmart C4280 all-in-one. Problem is only with label paper. It prints 3/8" too high throwing everything out. If I change the original, it is fine for three or four sheets but then changes again. It...
You've probably tried this, but I did have success today with Avery 8160 labels. I had been using 5260 labels. There is a difference at the top of the page in the way the backing lines up with the labels.
Nov 30, 2008 | Office Equipment & Supplies
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Samsung CLP 300 Laser Printer Logo
88 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
