2000 Suzuki VS 1400 Intruder Logo
Posted on Feb 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
94 suzuki 800 intruder. clutch splips in high gear. can I adjust it? hydraulic clutch
Fabrice Wolters
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Apr 02, 2009
Fabrice Wolters
Expert
Level 2:
Sergeant:
Answers
331
Questions
Helped
171536
Points
685
No adjusting is possible.
Slip can be caused by several defaults:
- Wrong engine oil ( SAE 10w-40 API SE or SF only )
- Weak clutch springs ( free spring length : 34mm ( 1.34in ) MINIMUM
- Worn clutch disk 2(internal teeths ) ( wear limit 3.15mm ( 0.124in ) ) This is the last disk, against the clutch center
- Worn clutch disks 1 (internal teeths) ( wear limit 2.62mm ( 0.103in ) )
- Clutch plates ( thikcness between 1.55 and 1.65mm / 0.0610 and 0.0649 inches
- Damaged pressure plate ( cracks round the spring holes )
To check the clutch parts, the right engine cover must be removed.
Take attention while loosening the clutch spring bolts!
Drain engine oil, and set engine into first gear ( this locks the clutch for an easy loosening of the spring bolts )
Hope it helps
My clutch seems to slip in higher gears on my suzuki intruder but takes off from dead starts just fine. what does it sound like the problem is?
Sounds like you either need to adjust the clutch cable - there should be a little bit of play in it before it disengages the clutch - or you need a new clutch kit (plates, springs, etc). What mileage is on the bike and has the clutch ever been changed?
1999 suzuki intruder hydraulic clutch
yes, WHAT ABOUT IT?? GOD ABOVE, WHAT.
2helpful
How do you adjust the clutch
Your bike has a hydraulic clutch set up. It is not adjustable.
1helpful
How to adjust clutch 1998 Suzuki VL 1500 intruder LC
The clutch on this model is hydraulic and is 'self adjusting", if the clutch is slipping the plates are worn out and in need of replacement. This information comes directly from the factory service manual.
I have a 1986 Suzuki Intruder VS700 - after I ride for about 10 to 15 miles the clutch lever loses compression and I can't shift gears. If I let it stand for about twenty minutes the lever regains enough...
You could change the fluid, but I'd pay more attention to bleeding the system a few times.
It also sounds like the clutch slave cylinder seals are worn/perished. You might need to look into having these replaced, as it could be allowing the clutch to seep fluid stopping the hydraulic (vacuum) affect.
Vote for me if this helps, thanks.
All gears from 1 to 5 are slipping. each gear
does the clutch lever release "sharply" and snap back after engagement? then lean bike over drain about a quart of oil, take off access cover to clutch and check to see if you have any broken clutch springs. if thats looks o.k. you"ll probably need new clutch plates. a real quick check when you ride the bike smell the oil, does it smell burnt? if it does, the plates are probably no good.
1992 Suzuki Intruder Clutch problem
THE CLUTCH PLATES COULD BE WORN ALSO THERE ARE ADJUSTMENTS BY THE CLUTCH LEVER TURN IT COUNTER CLOCK WISE TO TAKE SLACK OUT OF THE CLUTCH CABLE
1helpful
94 vs intruder dead starter switch
try adjusting /cleaning ,clutch switch
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
