Question about Mitsubishi WS-65511 65" Rear Projection Television
My Mitsubishi WS-65511 won't turn on.
Mitsubishi WS-65511 won't turn on with either remote or front panel. The scenario is this: after hitting the power button on either remote or front panel, the green light comes on for about 2 seconds then 'clicks' off and the tv never actually turns on. I have tried the reset procedure with no success.
This problem is identical to what occurred about a year ago - we actually had the DM board replaced about a year ago as it was still under the extended warranty at that time (of course, it is not now). After reading through other posts/solutions, it sounds like this may still be a DM board issue. I have disconnected the front panel wires to see if tv will work with the remote (in case front panel buttons had shorted), but this did not work. I have also tried to press the menu and device button simultaneously to get an error code but that does not seem to work.
Any suggestions? Does this sound like a DM board issue? Would replacing the capacitors do the trick?
  • apetsche Mar 03, 2009
    yes i also have the same problem with my ws-65511. its been a great tv until the last few weeks. it just started shutting off intermitenly,now wont even turn on. the green light comes on for a few sec. then turns off.the reset button did not help. my extended warrenty has not yet exspired, but the sound advice store in my area just closed down 2 mounths ago.i hope i can some help from the extended warrenty company. apetsche@live.com
  • wwharrison Mar 06, 2009
    It's been about 2 weeks and no solution has been posted yet. I am going to try replacing the capacitors (just ordered them). We'll see how this goes...
    Problem Solver:
  • 12 Answers
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Posted on Apr 15, 2009
Tip
Bypass Mitsubishi WS-65611 Front Lock
Bypass Mitsubishi WS-65611 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Reset Mitsubishi WS-65611 VChip Password
on May 04, 2010 | Televison & Video
Mitsubishi WS-65511 volume control has gone crazy. All of a sudden volume went to full blast and now with manually pressing volume button it is either full volume or lowest volume. We have DISH and...
Mitsubishi WS-65511 volume control went crazy after a storm. Now we don't having any volume. None of the controls are working on the front of the panel with the exception of the device control.
Jun 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
No control of WS-65511
The following solution has been posted in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 22, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65511 Front Lock
Bypass Mitsubishi WS-65511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65511 Manual Download
Reset Mitsubishi WS-65511 VChip Password
on May 03, 2010 | Televison & Video
Tip
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Tip
Bypass Mitsubishi WS-48511 Front Lock
Bypass Mitsubishi WS-48511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
1,161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
