Question about Harman Kardon Televison & Video
I have a HK TC30 remote control that will reset itself, displaying "Testing" and then indicates that the remote thinks all devices are off.
Try re-loading the firmware again through safe mode. 1. Take out the batteries from the remote. 2. Turn on your computer and hold the off/on button and connect the USB cable to the computer and remote. 3. The remote display should say "Safe Mode Requested". 4. Start the HK software and login, then click on Support. 5. In the download section, click on firmware and then proceed to update the firmware again. 6. After you update the firmware, you will need to re-download your configuration again and update the remote.
Posted on Mar 28, 2009
This solution doesn't work for me. My TC30 worked fine until I got this brilliant idea to replace the battery; since then reset galore. Mostly when I touch a key but sometimes even when resting idle on the table... also when something bumps against the remote it will spontaneously reset. My educated guess is that something is wrong with the powerfeed, like when touching a key the remote needs more current from the battery and that's when it goes berserk. I also can't seem to charge both batteries anymore with the standard deskcharger, maybe a standalone charger will do the job?! This is HIGHLY annoying!
Posted on Nov 08, 2011
I have an harman kardon tc 30 and give the message safe mode! B.2ACC
Any solution for this?
Posted on Sep 02, 2010
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic Televison & Video
Tip
Onkyo Remote Control Programming Would you like help programming your Onkyo...
Would you like help programming your Onkyo remote control to control other devices?
To program your Onkyo remote control, follow these steps:
  1. Hold down the REMOTE MODE button for which you would like to enter a code, and keep pressing it down.
  2. Press and hold down the DISPLAY button until the remote indicator lights up (about 3 seconds).
  3. Within 30 seconds, use the number buttons to enter the 5-digit remote control code for your device. (look these Onkyo remote control codes up in the codes list.)
  4. The remote indicator will flash twice to indicate a successful programming.
The Onkyo remote control codes, listed by brand, are available here.
I hope that helps.
on Apr 11, 2010 | Audio Players & Recorders
How to reset my remote RM-AAU104
Just take out the batteries from its compartment. The remote control will reset itself. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Feb 27, 2015 | Sony REMOTE CONTROL RM-AAU104 OEM Original...
MY TC30 HYDRAULICS DO NOT WORK IN THE WINTER,I HAVE CHANGED THE OIL TO F200A AND IT STILL DOES NOT WORK.
What exactly doesn't work? The loader? The remotes? You probably have a case of frozen cables, not frozen hydraulics. Most of the functions on your TC30 have a cable that actually moves the spool valve. If the control lever is stiff so that it doesn't move, then it is likely the cable. You might need to replace them, but first try spraying plenty of WD-40 in each end. You might need to take them apart to do this.
Dec 07, 2014 | Garden
Puedo conectar el alambre negativo del
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Nov 02, 2014 | Televison & Video
Open battery compartment on Logitech harmony 700
When you take out the battery, the remote will reset itself. You have to setup once more with the codes for your device.
Jul 13, 2012 | Logitech Harmony 700 LCD Remote Control
How to reset rch7h10 asda remote control
Just take out the battery from the compartment. Reinsert it. The remote control will reset itself. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jan 21, 2012 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
HK avr125 5.1, no display, no functions.
Same problem. C901 on the vertically-mounted input board next to the power supply transformer was burned. Replaced with ceramic cap from RS with same specs. Still did not work. Talked to Jeb, great guy at HK tech support. He suggested that R901 would probably be blown and maybe 902 also. These are flame-proof resistors and do not show damage. Tested with multimeter and Jeb was spot on. Replaced 1w resistors with 5w (all RS had) at same resistance. Works great.
Jun 20, 2008 | Harman Kardon AVR 125 Receiver
Televison & Video Logo
713 people viewed this question
Top Harman Kardon Televison & Video Experts
Electro Med Services...
hims Patel
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
