Question about HP w1907 LCD Monitor
Disable sleep mode
I have a hp w1907 monitor that i want to disable the sleep mode so that it dont go to sleep everytime i walk away from the computer
  • 741 Answers
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Posted on Feb 22, 2009
  • Randall  Trahan
    Randall Trahan Feb 25, 2009
    You do know how to read english and follow directions correct?
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
HP LE1901w -- monitor starts then goes into sleep mode
welcome my friends ,, all about football here !
http://www.news-football.org/ Football News
diego goals vs barcelone ! here ! Football News
Apr 24, 2010 | HP w1907 LCD Monitor
Monitor goes into sleep mode at random
Check your power options in your control panel - default is usually 20 minutes to put monitor to sleep - you can adjust the time there. The monitor itself does not usually have this as a function so I would start there first.
Mar 25, 2010 | HP w1907 LCD Monitor
My hp w1907 monitor goes dim after start up. It
More likely to have problem in the power supply, back light inverter circuits, or worst will be bad lamps. Look for bad caps with bulging top first, post back what you see so we can guide you further, see example of failed monitors mostly due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | HP w1907 LCD Monitor
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
As soon I turn on the computer, the monitor wil say it's going to sleep mode, nothing else appears. The cables are attached in the right slots.
hi
please try to take the computer in safe mode and then try to change the setting in display center and try to chage the value of power option and your computer monitor would be out from the sleep mode
Jul 07, 2009 | HP w1907 LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
478 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
