Question about HP Pavilion dv6000z Notebook
Red vertical line going down the screen'
Looks like a laser line going down the screen
  • Bayou Bob Feb 23, 2009
    Red vertical line down the screen. And, just started, a similar yellow line down the other side.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    see on external monitor if it is there then vga card problem if it is not there then could be flex cable problem or inverter LCD itself
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
That shows a bad LCD screen that needs to be replaced. Unfortunately it's a hardware problem.
If you laptop is under warranty, you need to take it to a Dell Warranty/Service centre and have the LCD replaced.
Feb 22, 2009 | Dell Inspiron E1505 Notebook
Red and Blue vertical lines top to bottom on LCD Screen
yes it looks like its going bad..must be pixel burnout or something..you will have to contact HP for repair/replacement
Nov 23, 2008 | HP Compaq nc8000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
1 vertical line going down the notebook LCD
Some of the many connections to the TFT screen panel matrix itself have have either been damaged or have decayed. These tiny connections are bonded along the edges of panel and are not viably serviceable. The most common causes are impact, stress (twisting) and condensation/moisture ingress. A replacement screen panel is needed.
Dec 16, 2007 | Compaq Presario 2100T Notebook
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Get onto HP Tech Support Team This will mean a new screen I fear.
Jun 18, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv6000z Notebook Logo
261 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
