Question about Dell Inspiron E1505 Notebook
Red vertical line going down the screen'
Looks like someone has a laser on my screen
    Sergeant:
    Champion:
  • 224 Answers
That shows a bad LCD screen that needs to be replaced. Unfortunately it's a hardware problem.
If you laptop is under warranty, you need to take it to a Dell Warranty/Service centre and have the LCD replaced.
Posted on Feb 22, 2009
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Two vertical red lines.
    need to replace main board. it can't be repaired. check vizio parts web site for availability
    Usually, they good with parts supply
    Take care,
    Alex's TV Service,
    Philadelphia,PA.
    215-806-5980..
    Jan 22, 2010 | Vizio P42HD Television
    Red vertical line down right side of the screen
    hi
    I think your TV have a trouble inside lcd panel
    the controller board contains driver IC. Deffective driver IC can cause of line display.
    Three reasons why one vertical line accross screen can happen in LCD;
    1.The missing signal from the controller IC to
    LCD driver.
    2. LCD driver IC itself defective
    3. Dry contact in the tape carrier package.
    Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
    Use robber
    Place the rubber on the top of TCP
    Gently close back the top casing
    Good luck...
    Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
    6 horizontal lines
    I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
    Hope this helps,
    Skyassoc
    Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Vertical red lines on screen
    LCD correct?
    There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
    1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
    2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
    In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
    Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
    Red vertical line appears intermittently
    you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
    Jan 23, 2009 | Hitachi 55HDX61 Television
    Vertical lines in my laptop screen
    Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
    Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
    Your responses are intended to improve the level of service provided. Please rate your experience.
    Thank You.
    Oct 19, 2008 | Dell Inspiron 9300 Notebook
    Dell Inspiron E1505 Notebook Logo
    154 people viewed this question
    Alun Cox
