Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Wireless Connetion Password
I just got finished setting up my GT704WG Wireless DSL Modem/Router from Verizon, but I don't know how to setup a password/passphrase on it? I need step-by-step instructions. If you can e-mail them, that would be great! (I have a Windows Vista system)
  • 36 Answers
By default your routers ip should be 192.168.0.1. type this in the address bar of your web browser. this should bring up your routers page. Navigate your way to the security settings, You should have to login at this point.
User names and passwords can be found here.
http://artofhacking.com/etc/passwd-actiontec.htm
try all of those and see which one lets you in.
now youre in simply choose a type of password WEP etc and create the password (one you will remember). This password will be required when you logon to the network. Windows should then remember the password for you. If you do forget the password which you wont (remember!) you can go back to your routers page and reset everything or just the password. This will take off the password or change it to what you want.
Hope this helped
Bob.
Posted on Mar 12, 2009
GT704WG wont pass internet connection
need to configure the router again with PPPOE settings on the router.
Oct 20, 2012 | Actiontec (GT704WG) Router
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
I have a Verizon Wireless DSL Modem/Router GT704WG and I want to know how I configure my NAT type from strict to Open so that I can play Xbox live better with no restrictions
hi,
you can try to follow these steps,hope these works
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again.
thanks and God Bless
Jun 29, 2010 | Verizon Communications Ethernet/Wireless-G...
Actiontec Gt704WG wireless problem
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
wireless setup
check if wireless is on
check chanel
las step
try this with ips suport is you reset mdoem it returns to factory settings
try to reset it with a paper clip or pen hold it for 20 seconds
May 03, 2010 | Actiontec GT704WG Wireless Router...
NO PSN with Actiontec GT704WG Verizon
If you can access the internet it is not a problem with the router. Are you able to access the PSN site but rejected when you enter your credentials?
Feb 04, 2010 | Actiontec GT704WG Wireless Router...
Anyone know default password for actiontec gt704wg dsl modem
The default settings are:
Username: admin
Password: password
May 14, 2009 | Actiontec GT704WG Wireless Router...
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
How do i connect my actiontec GT704WG to my ATT dsl ?
You need to input your AT&T user name and password in the router's setup page and set the modem to PPoPE.
Here is the user manual: DSL setup is on page 26
http://safemanuals.com/user-guide-instructions-owner-manual/ACTIONTEC/GT704-WG-_E
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Actiontec GT704WG Wireless Router...
Verizon GT704WG DSL Modem wants me to install software
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
Mar 09, 2009 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
324 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
