Question about GE Nautilus 24" Built-in Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Posted on Mar 04, 2009
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Jan 02, 2008 | GE Nautilus 24" Built-in Dishwasher
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
345 people viewed this question
Top GE Dishwashers Experts
Mike
Ned Halaweh
Ned Halaweh
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
