Question about Comtrend CT-520 Router
Internet speed i don't have the speed that i must have.is it router's problem or anything else?what should i do?
  • Chris  Morse
    Chris Morse May 11, 2010
    We need more information to help you.
    cable or dsl?
    Windows or mac version on pc?
    how many computers on internet connection?
    router and modem models?
    Computer specs: CPU RAM Video Card Hard Drive?
We cant come to a conclusion that .....its a issue with router ...there may some issue issue with the internet cable which is coming out of the house....first you need to make sure the cable which is connected to the modem is fine
Posted on May 15, 2009
Slow upload speed
It is usual that the internet speed differs when connected to a modem and a router. You have many possibilities to get signal affected while connected through a router.
Anyway you can try with these basic steps to get a better connection through router,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after performing these steps.
Sep 12, 2012 | D-Link DGL-4500 Wireless Router
Tip
Slow Speed due to router
hi there,
I had a problem, my internet was working slow on wireless and when connected with wire it use to fly like anything.
What i found from reading alot if that often people think that there router is conduction some problem after few years of usage and the signals are not omitting correctly or something.
However I got a simple solution for you all I found that the internet was absolutely fine when connected with wire.
So after doing alot of other activities i found that the FIREWALL was turned on, on both the devices i.e. My ROUTER and my DSL MODEM.
So please keep in mind usually there is not problem with the Router or the DSL modem if you feel the internet is slow please check your firewall and simply turn one firewall on either it should be routers or dsl modem.
Well this helped me and now i get good speed.
If there is anything i can help you with please do not hesitate to ask.
Thank you :)
on Mar 31, 2010 | Linksys Wireless-G WRT54G Router
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
Lock my d-link
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 27, 2011 | D-Link DIR-615 Wireless Router
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Am I getting high speed thru my actiontec gt704wg router
It depends on your DSL connection- technically anything above 56k is "high-speed internet"- if you are concerned about the speeds you are getting, contact Verizon tech support for further assistance- you could have an issue with your connection, and they would be the ones able to setup for a technician to come out/ have the maintenance office repair the connection
Aug 06, 2010 | Actiontec GT704WG Wireless Router...
Internet is very slow, latency is very high
Not the best gaming router out there would not use it for battlenet or war 3 to boot. I would get linksys gaming router by linksys. But to solve you problem you need to run your computer in dmz gamming mode also try any new firmware out there and see if that helps if not part with the netgear and get a linksys gameing router you be glad you did.
Nov 24, 2009 | NetGear WGR614 Wireless Router
I want to allow a fixed speed to my clients
With your current network configuration you can't do anything about this problem
Jun 23, 2009 | Xincom XC-DPG602 Router (XCDPG602)
Download speed slows when router is on line.
If the router is offline then your not downloading anything, most down loads start fast then fall to a level your pc can handle, aka your connection speed.
Apr 07, 2009 | Linksys Wireless-G Broadband Router
Need help
you reaqaly dont nned to pay for anything just get internet connection via wirless network (linksys,wireless router). that gives you wireless internet for computer, video game consoles and more. the router is bout 60-100 dollarz
Feb 18, 2008 | Nintendo Wii Console
Comtrend CT-520 Router Logo
104 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
Advaith Ganesan
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
