Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mit. WS-65615-65in-Can't change devices-goes into Sys Reset-off
1. Error code 12 so no errors
2. Have cable split so have basic cable and all controls on Tv and Remote wk. except for device, video/audio buttons
3. When Device, Video/Audio buttons pressed on Tv or Remote...no buttons wk and Tv goes into Sys.Re-set and turns off
4. So..can only watch basic cable and can't switch to other sources..Cablebox, DVD...Cam...etc.
  • SILKYR Mar 04, 2009
    I had to call Mit. to get the solution. The solution is one which I didn't want to do, but it's as simple as resetting the TV back to factory settings.
    In case you don't know:
    Turn on the TV and devices.
    Press 1,2,3 and the Factory Setting screen comes up and press Enter and the TV will default to FSettings.
    Of course, now you have to go back and re-set EVERYTHING.
    Your inputs are in the TV menu/Net-command. If you power up your devices, the TV is supposed to auto find them but my TV didn't have any of my devices stored so had to name and input them, but you may have better luck.
    :cheers:
    Silkyredd
    :wave:
  • SILKYR Mar 15, 2009
    Hey golfnwood
    You're Welcome..hate it when I find the same problem and it's been solved but no solution posted. I noticed in my post that I didn't say to use your REMOTE when you enter 1,2,3 but I assumed that would be the obvious thing to do, but thought I would throw it in there just in case for the remote challenged section. And if I'm ever in Phoenix again I'll let you know...beautiful area by the way..just too hot/dust/desert and not enouigh grass but sounds like that beer should happen on the course...FORE!!!!!
    SILKYR
I don't have a solution but wanted to say thanks SILKYR!!! I read what you said about your tv and calling mit about it. I had the same problem. Thought the worst on how to fix it.You saved me a lot of $$. You are ever in the Phoenix area I owe you a beer. Thanks for taking the time to post!!!!
Bryan
Posted on Mar 15, 2009
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS 65807 issue- Pressing power button turns unit on for about 5 seconds and then the power shuts off. Unplugged for about 30 seconds and disconnected it from all other equipment, reconnected...
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT(some sets the input is called device) together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Oct 31, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Convergence issue on Mitsubishi
Check your error codes first and see what error it's given. If done right it would last. see ctechnicians.com for how to do error codes
Jan 06, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
