Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Our gas stove repeatedly tries to lite
Our gas stove's flint is continuously trying to lite itself. How can we fix this problem?
  • GE Master
  • 8,220 Answers
One of the small switches mounted on the gas valve stems has its little contacts fried together. Sometimes pots poil over and water gets into a switch and after 4 or 3 day that switch goes all propah again. To repair the prob you must find the bad switch and replace it. Remove a wire from one at a time till yo find the bad one. Or simply replace the entire harness making sure each swicth is properly locked into place. Simple ain't it? LOL
Posted on Feb 22, 2009
Tick noise gas line from gas dryer up to kitchen stove
sounds as if you igniter is trying to continually lite not sure about how flame senser works on that model but normaly senser is right next to flame may have been bent away from flame I am use to older models
Feb 07, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
Cleaning lady accidently sprayed windex near our 6 yr old gas GE profile stove. It now makes a clicking noise. What should I do.
Hello there:
the clicking sound that you are hearing is the igniotor trying to lite the pilot s but the pilot lite is out what you can do is first lite all of the pilot lites manually and then start the burners normally as you would and now they should work ok
Also if you contact you local gas/ electric company they will come to your home and lite this stove for no charge ok?
I hope this is very helpful for you
Best regards Michael
Nov 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Got gas stove flints wet and wont stop sparking?
The problem is actually caused by water getting into one of the burner ingition switches. This will generally correct itself by just drying out over time. (usually within a day) Just leave the range unplugged for a while.
Oct 09, 2009 | Maytag Gemini MGR6751BD (Gas) Kitchen...
Just bought a Crosley stove. Burners will not light up.
Please remove the Gas Pressure Regulator and test it on another Gas Device (even a gas lamp). Then the next step would be starting investigating the Flint (lighter device) Reply if the regulator is confirmed to be working well - to continue with the testing of the flint
Sep 11, 2009 | Crosley Kitchen Ranges
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
The ignition spark for my gas stove won't stop flicking....
Jan 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
Oct 24, 2008 | Ovens
Oven will not stay on
sounds like the spark switch is gone out. have a technician replace it.
Sep 12, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
