Cant find a button
Cant find (+-) key. we checked but cant find it and we need it for a big test.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
You didn't specify the make and model of calculator, but here goes...
It may be marked +/-, CHS, or (-). If that doesn't help, please tell us what calculator you're trying to use.
Posted on Feb 19, 2010
2008 Big Dog Pitbull, turn key all lights comes on like normal hit run button then push start button and clicks and flashers come on and wont start have to hit right turn signal to turn flashers off?
Hi, Anonymous you may have a short in the handlebar control housing had them apart recently? otherwise, the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2010 big dog bagger won start
big dog will not start help Club Chopper Forums
08 BDM Service Manual
Big Dog Motorcycle Parts Speed Dealer Customs
http://rnbcycles.com/pdf/manual-2006-PITBULL.pdf
Oct 11, 2016 | Motorcycles
1997 Big Dog Vintage Classic at Sturgis, SD this weekend, just quit ! He (Art/husband) is out there looking for the problem..12 volt from battery to turn on switch Nothing after that In linefuse loca
Hi, Deborah and the usual suspects are:
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
13. Check for engine trouble codes.
What to do When Your Motorcycle Won Start
TROUBLE SHOOTING
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Big Dog manual 2005 all models pdf
Aug 15, 2016 | Motorcycles
350 big bear quad bike won't start unless I pull start it.
Hi, Connor and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Ignition start problems STUMPED HELP
Big Bear 350 Problem
DOWNLOAD Yamaha Big Bear 350 Repair Manual 1987 1997 ATV Download Manuals...
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/1999/Lit-11626-12-49_325.pdf
Jul 16, 2016 | Big Motorcycles
I cant check account balance on my blackberry 9630 and i cant browse
ok so here is what you do.. i had the same problem, go to options, mobile network, switch network technology to gsm/umts, switch network mode to 3g&2g, turn data services off, hold off key until device shut down, power back up, turn on data services, hit the menu button, select diagnostics test, hit menu button, select run... viola!
Feb 27, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Location of fuel pump on 97 cougar
97 cougar should have an in tank fuel pump if not its a big silver thing bolted to the right frame rail under the car forward of the rear wheel.
Nov 17, 2010 | 1997 Mercury Cougar XR7
Starter tests good. ignition switch on steering column replaced. still have starter problems. clicks when key turned, but motor spins only intermittently.
Will we know switch and battery are good, need to check for voltage at the big wire on the starter assembly, should always have voltage, that voltage comes from the battery right to the starter, while some one trys to start it, with test light check at big wire, if you have voltage at big wire, try hitting the starter, could be stuck, if you have voltage but goes away while trying to start, check connection's at starter and battery, also check body ground
Aug 05, 2010 | 1992 GMC Sierra
Put new battery in car and it wont even try to turn over. Is it the starter?
Check voltage at starter, there's a big wire and a small one, the big wire should have voltage all the time, the small one will only have voltage when key is at start, with test light check voltage at big wire, if no voltage check battery terminal's, if there is voltage then check voltage at small wire while some one hold's ignition key to start if you have voltage bad starter, also hit starter while key is at start some time's it will crank engine over, but you'll need to replace starter, if no voltage check ignition switch, good luck, hope this was very helpful.
May 19, 2010 | 1997 Honda Accord
Car starts but ac, windows, etc.. do not work
LOOK UNDER HOOD FOR POWER DIST.BOX,NEXT LOOK INSIDE AT THE BIG FUSES AND SEE IF YOU CAN SEE IF ANY HAS BLOWN.IF YOU CANT SEE THE LINES IN THE FUSES, THEN YOU WILL NEED A TEST LIGHT TO CHECK THEM.AFTER FINDING THE BAD ONE,REPLACE WITH THE SAME TYPE
Aug 20, 2009 | 2006 Toyota Sienna
Alarm light flashing saying check printer resume
It may be waste ink full
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Remote broke
The input button or volumn arrow key might work.
Aug 10, 2008 | Insignia IS-LCDTV32 32 in. Television
jasbo
jasbo
