Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
What does the error F31 on Bosch WAS32466GB mean?
What does the error F31 on Bosch WAS32466GB washing machine mean?
  • 139 Answers
SOURCE: washing machine
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump..
hope this helps cheers
Posted on Jan 21, 2008
SOURCE: bosch washing machine error code
e04 error not draining door won;t open
Posted on Oct 22, 2008
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
57 varieties
  • 1653 Answers
SOURCE: what does error f04 mean on a bosch washing
It means that the water is not draining fromthe machine inthe time allowed by the controller.
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Error code F31 on hotpoint wd72
I find no F codes for it only E 30 or 31 means motor failure and call service
Mar 18, 2015 | Hotpoint Washing Machines
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
E36 error code
My Bosch washing machine is showing error code E36 what's the meaning?
Feb 18, 2014 | Bosch Washing Machines
E29 comes up on Bosch washing machine what does this mean
BOSCH WASHING MACHINE E29 ERROR MEANS INLET VALVE CONECTION WIRE IS BROKEN.I FOUND LAST TIME....MY NAME IS KHAN.
Apr 10, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
What is code F31
The F31 error code signifies that the heat sink in your washer got too hot. The motor control unit (MCU) stops the motor and sends the error the the central control unit (CCU) and the CCU resets the MCU. After this happens 4 times the F31 code will show.
It could be an electrical issue in either the MCU or CCU. Many times simply unplugging the unit will fix the problem. Otherwise, service must be called for.
A&E Factory Service is a nationwide servicer. Their telephone number is 1-800-905-9505
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
779 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
