Question about JBL SCS300.7 System
I have a JBL sub300, Humming & burnt board
I have a JBL sub300, part of the JBL home speaker set SCS300.7. The subwoofer has developed a hum, and in looking at the amp board, there is a large hot spot.
I'm trying to find a replacement board. The numbers on the board are 104SUB15000 V06 & SCS150PW
Any suggestions on board replacement or repair?
  • Anonymous Apr 17, 2009
    I have the exact same problem. Any luck in finding a replacement? My subwoofer stopped working.
freetek
  • 5568 Answers
SOURCE: jbl sub300 has developed humming sound
Make sure all of your cables are seated well; this can come from poor shielding of low-level audio cables. If all seems in order, then the power supply for the subwoofer has poor filtering that can come from a failing electrolytic capacitor.
If you plan on DIY service, here is a link to the manual:
JBL Sub300 manual
It is said to be 60 pages long.
Posted on Oct 17, 2009
When I turn the volume control on my home powered subwoofer, it makes a humming sound, then it stop working
check your connections, RCA, Speaker wires, maybe there is grounded. try other wires which you think in good condition..
Aug 10, 2012 | JBL Audio Players & Recorders
My subwoofer makes a humming noise
In most cases when you have a humming from anything electronic it is being caused by a bad filter capacitor in the power supply. Filter capacitors look like little cans. Look for units which are bulging. If so replace them.Electrolytic capacitors are so cheap even if none are bulging you could replace them all for less than $10. Try that and let me know.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | JBL ES150P Subwoofer Speaker
Jbl sub300 has developed humming sound
JBL Sub300 manual
Oct 17, 2009 | JBL ESC-300 Speaker
Humming from SUB333
Replace the plug, they most likely had a ground loop where it was plugged in and cut the common to get rid of noise. Replacement ends are easy to find at Home Depot, Lowes, ACE, etc. Try that first, if you still have an issue, post a comment and I can help you further. Hope this helps
Jun 20, 2009 | JBL ESC-300 Speaker
My jbl sub 300 has developed a loud humming noise
could be the woofer but it is probably the amp. better bring it to a service center for evaluation.
cathy@speakerex.com
Jun 06, 2009 | JBL ESC-300 Speaker
Humming noise follow up
I'm fairly sure this is a power supply problem; less likely, a shorted power output stage which may be a largish integrated circuit; this last one would probably be costly to replace.
A failed diode or filter capacitor in the supply can cause this by either (the diode) allowing unrectified AC to pass or (the capacitor) poor DC filtering of the rectified AC. Neither of these parts is expensive.
Diodes can be in a variety of different packages so giving guidance on these is tough. Capacitors of the type likely used as the main filters in your power supply will be cylindrical objects between 1/2" (12-13mm) to 1 1/2" (~37mm) in diameter and between 1/2" to 3" (~75mm) tall. Caps are in aluminum cases with shrink wrap that will have values given in microfarads (µF) and VDC (Volts DC). Often, when they fail, the exposed tops will bulge visibly as a sign of their failure and sometimes they will leak from the bottom rubber seal and there will be traces of a white deposit on the board around them. If you see such signs, replace them.
Checking power supply diodes could be done with any multimeter but unless the electrolytic capacitor(s) fails catastrophically as above, the main filter caps would need to be verified for value and losses with a capacitance meter which is too expensive to buy for home use. A plain-jane digital multimeter can cost <$20 US and would be useful for many other tests around your home and car as well.
Sep 06, 2008 | JBL Venue SUB12 Subwoofer
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
Mar 25, 2008 | JBL PSW-D110 Speaker
Noise when it turns on
have you checked your music source? Some systems like computers have a sort of output first before normalizing, which isn't your powered subs or powered amps problem. Try plugging in a regular solid state player like an ipod if the humming is still there when automatically turning on or off...
Dec 06, 2007 | JBL PB12 Subwoofer
Jbl subwoofer
There is actually some good news.  I had this problem with my PB10s (1 have 2 PB10s and 2 PB12s) It is one of 2 things, the first is that it could be a capacitor and resister combination on the amplifier board (which was the fix for our PB10 with the same problem), or 2nd, the AMP IC, which is not available for the PB12. hmmm
Sep 10, 2007 | JBL PSW-D112 Speaker
JBL SCS300.7 System Logo
864 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
