Question about Fuji FinePix Z10fd Digital Camera
Fuji z10fd no power after lcd replaced
I have fujifilm z10fd that the screen went bad on. I got a new screen and replaced it, but it won't power on now. It turned after the screen went bad, you just didnt have a screen.
  • calmaxy Mar 23, 2009
    where did you get the new screen from ? I have the same problem and am just wondering if its cheaper to try and fix it myself or just get a replacement camera.
I have repaired several of these. On most of them I found that one or both nano fuses on the main board have gone bad. They are labeled F2 and F3, they are 2 amp nano fuses. They are located on the back side of the main circuit board, near the top. Right at the top of the SD card socket. You will need to use a soldering iron, and desolder both Battery contacts. Also several wires on the main board will need to be desoldered, to get to the fuses. You should have some experience working with surface mount components and soldering before attempting the repair.
Posted on Mar 30, 2009
Lcd broken.Any chance to change lcd.
yes LCD's are a pain to replace on your own but luckily I'm here to help... please remember to rate me for helping you
the easiest way is to buy a new LCD
such as here:
finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html">http://www.ownta.com/fujifilm-finepix-f30-digital-camera-repairing-lcd-display-screen-replacement.html
or on ebay:
http://cgi.ebay.com/FUJIFILM-F40-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320283316623QQihZ011QQcategoryZ64352QQcmdZViewItem
Follow link to ebay vendor: Most lcd display screens are available
or you could build your own but without a ton of experience, this is more of a challenge than it's worth.
I hope this helps :)
Jan 04, 2011 | Fuji Cameras
Replacing LDC screen on Fuji Z10FD camera
Probably, yes.
Remove the 2 screws on the side,
Remove the 3 screws in the buttom. (2 of which are tri-wing)
Remove the 2 screws in the battery compartment.
Flip out the chrome side (from the front backwards)
Remove the 2 screws underneath the chrome side.
Turn the camera upside down. You can now flip the backcover down (gently lift the cover, both on the mid by the tripd hole and on the side, where the crome plate was) Watch out for the USB connector.
Gently lift the broken LCD out. You need to release (flip up) the tiny white lock on the connector to release the ribbon.
Assembly same procedure, but backwards.
Beware of the flash components. The can give a nasty electrical chock.
May 21, 2010 | Fuji FinePix Z10fd Digital Camera
Get the date on the photos
CANNOT PUT DATE ONTO PICTURES ,,HAVE FINEPIX Z20fd
Jan 11, 2009 | Fuji FinePix Z10fd Digital Camera
Have found you an online PDF Version of the Z10FD Users manual you should get in the box !
you need adobe acrobat to be able to view this !
http://www.fujifilm.com/products/digital_cameras/z/finepix_z10fd/pdf/index/finepix_z10fd_manual_01.pdf
Hope this helps !
Oct 28, 2008 | Fuji FinePix F480 Digital Camera
My fuji finepixz10...
Hey big mike08,
Make sure your LCD mode is not set to power save mode which if it is set to power save mode the image you just took will not display on the LCD immediately after the image is taken. The LCD mode can be selected in the set up menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 23, 2008 | Fuji FinePix Z10fd Digital Camera
Fujifilm z10fd card error
Easiest way to fix the problem is to "format" the card using the set-up menu. Follow the steps from the menu to the format setting. That will erase everything on the card, including any images that are on it. It will also wipe out any bad or corrupt data that may be preventing the camera from reading it properly. It's pretty common.
May 01, 2008 | Fuji FinePix Z10fd Digital Camera
LCD screen wont work
I had this problem w/ my canon. It is a cracked LCD screen. I took the camera apart and replaced the LCD screen. I ordered the new one for $50 including shipping. you may have to do some detective work to find the part you need. I used a screwdriver for eyeglasses.
Mar 27, 2008 | Fuji FinePix A600 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
206 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
