Question about Linksys Wireless-G WRT54G Router
Disconnect my system only picks up other signels not mind keep droping off
  • Anonymous Feb 24, 2009
    Connection keeps dropping off, and then trying to connect with other networks. Mine is the only one set to automatic--the others have been deleted.Pain in the ****...
  • Chuck May 11, 2010
    do you know how to setup a router?
    are you trying to configure it through another computer that is diretcly connected to this router?
    sounds like you need to configure it better? or check for a firmware update on it most likely you need to do this if you havent.
    Scholar:
  • 141 Answers
Delete preffered networks from your wireless computer then try to look for your wireless network again. It should connect. Call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Posted on Feb 24, 2009
No brake lights on 1999 gmc k3500
Where the brake lamp attatches to is called a tail lamp assembly,some call it a rear light module,they are sold in pair and they do fail,you did the brake switch and the combination switch,either the wire is disconnected some how or the lamp assemby both side failed,
Dec 09, 2012 | Cars & Trucks
How can i bost the signel on a linlsys E1000
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Feb 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
THERE IS A SIGNEL PROBLEM FOR MY W910i ' .SOME TIMES THERE WILL BE SIGNEL SOME TIMES NOTHING.. IF I STAND NEAR THE TOWER ALSO I HAVE THIS PROBLEM... PLEASE HELP ME
Try and any software update. Go to setting and u gobs updates. Also try keep the phone on and take the battery out it fixs error Pop battery back in and turn on phone see it tat makes it better
Jan 16, 2011 | Sony Ericsson W910i Cellular Phone
My screen is black because i droped it how can i fix it?
Its either the screen is now disconnected or it is broken. If it is just only disconnected, once reconnected it should be back up and running. But if on the other hand is broken, you will have to replace it. If you are technically minded you may be able to open it up gently and check to see is the connection from the screen to the panel is weak. If weak just press it back to hold firm and couple back the phone. If after this problem persists, you will need to replace it.
Sep 10, 2009 | Nokia 5300 Grey Cellular Phone
Radiator water level keeps on droping
You coolant system needs to be pressure tested to determine a possible leak or intake gasket problem. The radiator and reservoir caps as well.
If that all checks out ok...then a cylinder compression leakdown test is advised.
Good luck...i hope this helps..please rate me a fixya
Jul 29, 2009 | 2000 Mercedes-Benz C-Class
Won't TURN ON!!!
maybe your screen is damaged because i had a phone and droped it and the screen went black and it could not be fixed.
Apr 09, 2009 | Digital Mind Corporation iQ Sound...
2007 town and country
U have a defective gas tank sending unit.
Dec 25, 2008 | 2007 Chrysler Town & Country LX New Cars
Always get a busy signel on fax and cannot get fax through
Check to see if there's an answering machine picking up before the fax machine gets a chance to answer. The person receiving the fax might need to temporarily disable their answering machine first.
Nov 12, 2008 | Office Equipment & Supplies
Nokea slider
Your service provider should be able to replace it.
Jun 22, 2007 | Nokia 6288 Cellular Phone
Linksys Wireless-G WRT54G Router Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
