Question about LG 24 in. LDS 5811 Built-in Dishwasher
Plastic clips failing
All the plastic clips that hold the parts of the dish rack together and hold the disk rack wheels onto the disk rack are failing. They become brittle and break. I have replaced all of them twice already. They only seem to last about a year and a half.
  • Anonymous Mar 28, 2009
    I had the same problem. At first, LG was very uncooperative, but last time I called, they were the opposite....maybe they had a customer service initiative after reading all these complaints! In any case, they sent me 10 new wheels, even though our unit was out of warranty.
  • 423 Answers
Hi Tom,
Can you confirm that you are talking about the LG 5811 dishwasher? Thanks!
Posted on Mar 29, 2009
The top rack does not sweem to get water spay. I put a glass upright on top rack and it did not fill up. The bottom dishes are getting clean could it be the circulating pump
There is a plastic cone on the back, bottom of the top rack. The cone must push into the water tube in the back wall otherwise noo water will get to the top. Make sure the clips holding the cone in place are positioned correctly.
Jul 08, 2011 | KitchenAid Dishwashers
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Top rack dishes not getting clean
When the dishes on the top rack are not getting clean the most common problem is that the water supply hose in the rear of the top rack is misaligned. With the rack empty, pull out the rack and look in the rear where the supply hose slides into the water supply. Often a plastic clip or two has come apart. Realign everything and it will work fine. If you need a diagram go to sears direct parts where they have an excellent website. Enter your model number and you will be able to see a schematic showing each part and how they go together. Joe
please rate my answer as very helpful. thank you.
Apr 04, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
GE dishwasher nautilus - bottom tray caster wheels come off daily.
I finally found a solution after 2 years! Appliancezone.com has wheels and studs to fix problem. WD12x10136 and wd12x10277. About $17.00 and rack is rolling perfectly. GE wanted 200 for an entire rack, no thank you!
Apr 06, 2008 | Danby DDW1805W Designer Series...
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
158 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
