Question about Frigidaire GLGR341AS Gas Dryer
I HAVE A FRIDIDAIR GLGR341AS1 MODEL DRYER. HAD SOME THIMPING IN THE DRUM AREA. TOOK OFF THE DRYER FACE AND NOW CANNOT GET IT BACK ON. THE CLIPS ON THE BOTTOM SEEM TO NOT SET CORRECTLY. ANY SUGGESTIONS ON THIS? PLEASE HELP. THANKS!!!
  • 40 Answers
Have to set the bottom first then lift drum to clear felt on front panel make sure the tabs on the fornt bottom corners are not bent or broken they should be up at an angle
Posted on Feb 23, 2009
Need to replace wiring harness on LG dryer DLE7177RM model. How can I connect the wires that extend inside behind drum?
Dryers are very easy to repair.
Video on how an electric dryer works: http://youtu.be/2xUKBtLkaeo
Video on how a gas dryer works: http://youtu.be/mcipN8bvpa0
Best regards ~
Mar 16, 2014 | LG DLE7177 Dryer
Can't get the front face off
After removing the screws holding the front panel in place, you may also see a series of clips that hold the panel. These clips will also need to be removed to remove the front panel. Another issue may be the drum rests on the lip of the dryer door. You may need to pull up on the drum while pulling on the front panel. Keep in mind that prior to removing the front panel, the top panel also should be removed. Also, remember to remove screws holding the lint trap in place. Depending on the dryer, this can be located on top of the dryer or just inside the dryer door.
Dec 28, 2011 | Samsung DV220AGW Dryer
Threading the dryer belt on my stackable frigidaire model. i need a diagram please.pulleys,tensioner and drum it is not getting tight. just need a pic.
A model number would have helped me help you a lot quicker. It took a lot of time just to try and guess here.
Yours will be one of these 2 diagrams:
westing.gif for 1995 and newer models ^--NOTE Belt ribs away from the drum on this one: frank.gif 1985-1995 models ^-Note: Belt ribs face drum on this one Thanks for choosing FixYa, Kelly
Aug 17, 2011 | Dryers
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
Makes a strange noise, as if something is rubbing. The dryer works, I took off the bottom front panel, and evrything seems fine, ie the belt looked fine, no debris found.
Most noise complaints from this style dryer comes from the idler pulley and two drum support wheels. The idler pulley just clips into the bottom of the dryer and keeps tension on the drum belt. The drum rollers have clips that must be removed from the shafts before trying to replace them. If one wheel is worn out, replace them both = less problems later on. See "how to take apart" to access the rollers, once the belt is disconnected from the idler pulley and motor pulley, lift out the drum. The roller on the left has a bracket and 2 clips to remove before the roller can be replaced. The right roller has just 1 clip that must be removed to replace the roller. Use a cloth or fine sand cloth to clean up the shafts, use a light oil before installing the new rollers. DO NOT use a heavy grease as this will attract dust and become very dirty and gum up the rollers. Check the belt will you are there and clean out any dust from motor and from the drum base. See how to take apart information. Anew picture of the roller, shaft and clips... you can get the required board and components at ----- www.partselect.com -------- or from ------ www.repairclinic.com ----
if you are not familiar with doing this you can get it done by local appliance repair technician familiar with this model.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Kenmore Dryers
MOD T700 ASKO DRYER REPLACED DRUM ROLLERS PUT BACK TOGETHER WILL NOT TURN ON
When I took the back off my Asko to clean it out I had to lay it on its face to get the drum to line up again with the back - in the doing this a wire pulled off its setting. Did not figure this out until I took the top off the dryer and found the loose wire. I have no idea if this is your problem but it was very frustrating. There is also a black reset button on the back of the dryer that you might try.
Jun 15, 2009 | Asko T701 Electric Dryer
Dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Apr 11, 2009 | Frigidaire Dryers
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Our Frigidaire GLGR341AS1 Does Not Start
see if you can turn the drum my hand... Makeing sure nothing is stuck in blower fan... if you can... sounds like motor my be bad
Oct 13, 2007 | Frigidaire GLGR341AS Gas Dryer
Frigidaire GLGR341AS Gas Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
