Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
My HE260A is discharging too much water
My HE260A whole house Honeywell humidifer is discharging too much water.
  • v5rg Apr 12, 2009
    The water continues to run. I thought that it should stop once the furnace turns off, but that is not the case.
  • mark1954 Apr 18, 2009
    This is the second season we've had the unit. It didn't do that last year. I think I have to replace the solenoid. Can anybody confirm?
Problem might be the sail switch is not shutting the water flow off after the furnace blower stops. Check to see if it is stuck in the "blower is running" position.
Posted on Nov 02, 2009
  • 118 Answers
These are flow thru models and a lot of water passes thru them. The instructions say to not limit the water by closing valve at all!
Posted on Oct 29, 2009
How long should it take a licensed plummer to install this unit on a new furnace?
Hello, typically it should take about a hour and a half to install a humidifer, usually takes me an hour and a half to two hours to install one. Anything over two hours is too long.
Feb 24, 2011 | Honeywell HE360A1027 Whole House...
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
I just finished hooking up my new he 220a HUMIDIFIER
I have a HE220, HE 260 humidifier..by pass, flow thru. There is no water flow between the hot water tank and the humidifer. The water valve is on. Is there an inexpensive part I can replace myself first before calling a plumbing contractor?
Dec 30, 2009 | Honeywell HE220A1019 Whole House...
Too much water running through to humidifier
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question,
mr.grzz
Jan 25, 2009 | Honeywell HE220A1019 Whole House...
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Water not running through humidifer
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
Nov 18, 2007 | Honeywell HE220A1019 Whole House...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
928 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
