Question about Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker
Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
I tried to make coffee without having the plastic lid on the stainless steel carafe. Upon noticing this (during the brewing cycle) the coffee was backed up into the filter area but not overflowing. I pulled the carafe out and replaced the lid and allowed the coffee to drip into the carafe.
But now the machine is broken.
It lights up and is blinking but none of the buttons work.
Does it just need to be "re-set" or something? I hope it's not damaged for good, having it only for 2 months.
  • Anonymous Mar 23, 2014
    Broken glass carafe. I need a replacement carafe or a thermal jug
  • Anonymous Mar 26, 2014
    stainless steel french press coffee pot
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Posted on Feb 23, 2009
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
How to re heat coffee after making
Pour it in a cup, then reheat it in a microwave oven. Do not place any metal in a microwave oven.
Apr 22, 2014 | Krups FMF5-14 Stainless Steel 10-Cup...
Need a replacment Carafe for a Gevalia CM500 Coffee Maker
www.ebay.com
In the EBay Search box, paste in: Carafe for a Gevalia CM500 Coffee Maker
You'll find several for sale
Mar 30, 2017 | Coffee Makers & Espresso Machines
Glass carafe broke on my ever star cofee pot
here's a new one http://www.thebigcoffeestore.info/send.php?s=aHR0cDovL3JvdmVyLmViYXkuY29tL3JvdmVyLzEvNzExLTUzMjAwLTE5MjU1LTAvMT9pY2VwX2ZmMz0yJnRvb2xpZD0xMDAwNSZjYW1waWQ9NTMzNjkxMzYwMyZjdXN0b21pZD0maWNlcF9pdGVtPTExMDc0MjI5NTc4MSZpcG49cHNtYWluJmljZXBfdmVjdG9yaWQ9MjI5NDY2Jmt3aWQ9OTAyMDk5Jm10aWQ9ODI0Jmt3PXJzcw==
Feb 09, 2012 | Haier HDC10LBS Stainless Steel 10-Cup...
Can get maker to run on manual
hmm get cute with it and just set it to brew in a minute from now. try that I'll be back after some homework, Did it use to run on manual? my last coffee maker had to push auto on twice for it to brew on the spot.
Mar 05, 2011 | Krups FMF5-14 Stainless Steel 10-Cup...
Our brand new Cuisinart model DCC-1150 10 cup coffee maker with the stainless steel thermal carafe makes a great tasting cup of coffee but the coffee isn't piping hot when first made and the carafe doesn't...
I am having the same problem, along with the coffee leaking onto the counter. I think this coffee pot is just defective. If not, I wish someone would come up with an answer.
Oct 21, 2010 | Cuisinart (DCC1150) 10Cup Coffee Maker
Krups fmf 5 water leaks from the bottom of coffee maker
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Jul 23, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker Logo
812 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
