Question about Samsung Digimax A7 Digital Camera
I buy a new video card the guy on store tell my the this is the video card the i nead and the camera dont acept said the camera nead diferen format and try to do teh format automatic and dont work can any one now how to fix this problem the video card is SDHC CARD THIS IS A DIGIMAX A7
  • 864 Answers
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
I have a polaroid dvf-720 brand new and trying to record and 2mins and it says memory full? i dont understand,and i have a memory card that says card error,need help or im in trouble with the wife!
Ok so I have the same problem I went out and purchased an SD card...but it doesnt work. So I called Polaroid and you need to purchase a CLASS 6 SD card of 2gb or more for it to work properly...figures it does not say that in the manual.
Dec 25, 2010 | Polaroid Cameras
New battery new sdhc 4 gb card. asking to format. When I go to set up menu, then format, it will not acept card. ??????
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 25, 2010 | Kodak EasyShare Z740 Digital Camera
Olympus Stylus, keep getting error message to format card. Formatted card and had to erase pictures in the process. Took more pictures and got error message again. Plugged camera into PC and there are no...
Hmm....
Seems like your Memory Card already damaged and corrupted.If you still want to use it, try formatting it using your Computer, again and again.
If the problem still persist, there's no other way, you have to buy the new ones.
Dec 08, 2009 | Video Cameras
Memory SD full
Can you put the SD card in an external card reader and see any files? Did you format the sd cards in the camera? You should never format the cameras sd card with a pc.
Apr 14, 2017 | Vivitar ViviCam 3746 Digital Camera
Card for above camera
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I used the procedure set out by dwafellman and it worked for me too! His translations from the French are, in English: Control Panel (configuration panel)>Administrative Tools (administrator utility)>Computer Management (computer utility )> Disk Management (disk utility) in Storage (stockage). I. e., Control Panel>Administrative Tools>Computer Management>Storage>Disk Management.
Mille merci, dwafellman. Vouz m’avez sauvé un voyage á Office Depot pour retourner mon mémoire Flash.
imallan
Aug 22, 2008 | Konica Minolta DiMAGE 7 Digital Camera
Nikon digital camera malfunction
Hey jackie jean,
If the two year extended warranty you are talking about is a performance service plan purchased at a Best Buy™ store then you could bring the camera into a Geek Squad® precinct in a Best Buy™ store, and they should be able to send it out for service at no charge to you. I am assuming you formatted the memory card in the camera, but if this is not the case and you have formatted the memory card using your computer then I would suggest formatting the memory card in the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix S51c Digital Camera
I want my pictures..please HELP!!!
This has happened to me before. What I did was just use the cord that came with the camera and plug it into the computer and just get it off that way. So then you will still have your pictures and it will be safe for you to format your card.
May 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Memory Full Error
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
Jul 05, 2007 | Samsung Digimax S700 Digital Camera
Canon powershot s2 Is
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Samsung Digimax A7 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
