Question about Apple iPod MP3 Player
Turning off IPOD 1059
I cannot turn off my IPOD 1059, what am I doing wrong? I press and hold the center white button, but nothing happens.
    New Friend:
Hey! I bought my ipod 8 months ago . It is second hand .but i couldn`t use . Today i want to use but it is not charging . I don`t no why my ipod is 20gb and model A1059 i thing it is old model.
Posted on Jul 01, 2013
    Scholar:
  • 85 Answers
If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Turning off IPOD 1059 - ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on Feb 22, 2009
  • 3 more comments
  • Chuck Feb 22, 2009
    oh i see you might be doing the reset wrong it is two buttons you must be pressing for 8 seconds not just one
  • ritt Jul 01, 2013
    Thanks C Farrah i will do it and i will tell you
  • ritt Jul 02, 2013
    I have done all but it is not working again i tell about my ipod , it is 20gb model A 1059 serial number 2Z6015ADPS9 there is no on switch only top wrote hold
  • Chuck Jul 03, 2013
    try the wall outlet. if none of these work i might have to say it might be a paperweight unless you want
    wow it didnt put in my solution. sorry this site i cannot edit it. so lets start again. the hold switch can show 'no orange' slide it back and forth once and now if that procedure didnt work that i posted earlier, i have to say to plug it into a wall charger for at least an hour and try again while plugged in.and to turn it on you just need to press any button for about 1 second and it should turn on but i would say to do this when it was charging for an hour and leaving it plugged in while doing this. do not use PC! so try reset procedure again while plugged in and leaving plugged in for at least an hour. if none of these work it might be a paperweight and cheaper to pick up a new one rather than having someone fix it.
My nano 4 gb ipod does not turn on--turning the switch on and off several times and pressing to turn and nothing happens. I even tried connecting to my computer--and nothing. Can you please help me? thank...
If you ipod will no longer turn on mostly it a battery issue
try this to tell for sure
-connect ipod to computer
- open itunes
- makes sure the hold button at the top is no in the on ( red ) position
- hold the menu and the center button at the same time for 2 minutes
- if the apple logo comes up then it should reboot and go back to the main menu
- if it dose not you need service / repair
Hope this helps
Jun 20, 2010 | Apple iPod nano
Got new wireless remote but would not work, center light comeson but nothing happens
This is simple. You just need to sync your remote to your Xbox. Do this by turning on your xbox, then turning on your remote, then at the top of your remote (between the LB and RB and next to where it can plug in) there is a small white button. Hold it until Your controller lights start spinning. then on your xbox press the similar white button (located near your memory card slot) and that should do it! Viola instant xbox satisfaction!
Jan 17, 2010 | Microsoft Xbox 360 Console
I was just using my ipod, and the screen went white... I tried the menu/center button but nothing happened.
Turn the touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Nov 25, 2009 | Apple iPod nano
My ipod chromatic is completly frozen.
You are doing the reset wrong. Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano MP3 Player
ITouch won't turn on
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Jan 27, 2009 | Apple iPod touch
Ipod nano 4th generation 8gb purple wont turn off
no there is nothing wrong. This is normal, after you turn it off by pressing the hold/pause button switch it into the locked position. When you take the lock off and press anything it will come back on exactly where you left it. Don't worry it is not faulty. it is supposed to do this.
I hope this helps
Jan 10, 2009 | Apple iPod nano MP3 Player
The screen is on, but there is nothing on it
have you tried resetting it?
if not press the center button and the menu button and hold for a couple seconds
And also Make sure you press Center FIRST (hold this down) then press and hold the menu button while keeping the center button held
Nov 21, 2008 | Apple iPod nano
My ipod nano wont do anything
Press and hold the center button while pressing down on the menu buttton. The Apple logo will appear. This will reboot your Ipod.
If that doesn't work, restore your Ipod to factory settings by plugging your Ipod into Itunes and select restore to factory settings from you Ipod settings in Itunes.
Aug 25, 2008 | Apple iPod nano
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
Feb 22, 2007 | Apple iPod nano
Apple iPod MP3 Player Logo
157 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
