Question about Epson Stylus Photo R320 InkJet Printer
Epson R320 "General Error" message - unable to clear
Situation: Wife pulled a crookedly-loading piece of paper out of the machine. She reported a grinding sound followed by the "General Error" message on the control panel and the maintenance (ink) light illuminated.
When I got to the machine the printer head was locked in a far right position. I have been on message boards all morning and have eliminated ink drainage as an issue.
I opened the cover and, using a small screwdriver, pushed against the white tab/dowel behind the print head to release it, and moved it to the left. Visual inspection confirmed no paper jam or bits of paper in the visible paper path.
Next, I powered off the printer. Then, pressing the "Stop" and "Power" buttons for 7 seconds, the print head began moving back and forth across the white tab several times before stopping at the end of its initial charging cycle. I repeated this process several times with the same result..the print head stopped at the right of the carriage, the maintenance light on and error message repeated.
On my fourth attempt, the "General Error" message cleared and the printer appeared ready to print. I loaded paper and attempted to print only to receive a paper loading error. I confirmed that paper was loaded correctly and attempted to print again. This time a grinding sound occurred and the print head locked on the right side of the carriage again.
Done all I know how to do. Any suggestions?Thanks,Clint
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
  • Epson Master
  • 541 Answers
Try downloading the ssc this will reset your printer
Posted on Mar 03, 2009
2 Suggested Answers
  • 1218 Answers
SOURCE: Epson R320 carriage jammed
General error see printer documentation to clear error how do i do this
Epson T60 Printer shows the Cartrage and paper light on together and did not work?
Aug 06, 2011 | Epson Stylus Photo R320 InkJet Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Any info on r320 general error fix . Had a paper jam and cant reset error. epson support usesless just say tech it to an authorized dealer to get it fixed.
1. you may have paper debris in the roller gear and therefore shut down.
2. you roller or transfer gear is damaged and needs replacement.
Apr 15, 2010 | Epson Stylus Photo R320 InkJet Printer
General Error Message
The "General error" message on the Epson R320 (as with most other Epson inkjets) can mean a whole host of things.
The most common ones are:
  • Printhead carriage blocked
    (something is blocking the printhead from moving left and/or right properly)
  • Cleaning/Parking pad area blocked
    (the printhead can't reach it's normal resting position)
  • Disconnected sensor
    (a ribbon cable has become disconnected or a sensor has failed so the printhead or paper location is not detectable)
  • Cartridge chip sensor issue
    (one or more of the cartridges has not been installed properly, has a "bad" chip or the sensor wires in the printhead carriage [where the cartridges sit] have been damaged)
If you can provide a bit more information on the error, possibly from the status monitor software that might give a bit more of a clue but hopefully the points above will give you a few places to look for possible causes.
Mar 15, 2009 | Epson Stylus Photo R320 InkJet Printer
General error on my epson stylus photo r320-
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Epson Stylus Photo R320 InkJet Printer
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
1.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
General error
i have some problum of epson r230 printer general eror please send me this problum solution
thanks
Oct 20, 2008 | Epson Stylus Photo R320 InkJet Printer
Unable to initialize
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus Photo R320 InkJet Printer Logo
2,722 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
