Question about Emerson Smartset Clock Radio
Alarm not working properly for model # cks3020 suffix#b
    President:
  • 814 Answers
Http://www.emersonradio.com/owners/SmartSet%20Series/CKS3020_072706.pdf Copy this web link and paste it into the address bar of the browser. This will take you to Emerson customer support web page that contains a pdf copy of the owners manaual for your model Clock/Radio. Here you can find the correct procedure for setting the alarms for the Clock/Radio. If the alarms still do not work correctly. You will have to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. Let the Clock/Radio set for at least 1 hour without any power source. Then reinsert the battery and plug in the Clock/Radio and see if the functions return to normal. If not you will need to call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of you Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Posted on Jun 12, 2009
How can I turn off the touchless snooze on my Emerson CKS3020? The radio goes off when I sit up.
Emerson Research CKS3020 Owner Manual
Emerson Research CKS3020 Owner Manual Page 7
The second link shows you the number 28. That is the location of the "Wave sensor." I suspect if you cover it, it can not detect your motion.
Sep 04, 2017 | Emerson Audio Players & Recorders
What is an Adherent suffix
This is not a proper question. Are you asking what suffixes does "Adherent" take, or what suffixes does "Adherent" already have?
I believe the answer to both might be "There aren't any." Adhere is a verb. Adherent is an adjective. If you want to pretend that adding "-nt" to adhere is a suffix, then I suppose it would have the meaning of "takes the form of" or "has the properties of." Adhere means "to stick to." Therefore, "adherent" could be "sticky."
Feb 10, 2014 | PREFIXES AND SUFFIXES
English manual needed
The manual for the Emerson SmartSet Dual Alarm clock, CKS3020, is available from the Emerson Radio Customer Support site. The direct link is http://www.emersonradio.com/resources/owner_manuals/manual_1312917881.pdf . This is a pdf so you will need Adobe Reader or a similar product to read the manual.
I hope this helps.
Nov 13, 2011 | Emerson CKS3020 Clock Radio
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
CD Alarm Clock displays NO DISC when attempting to play a CD.
try cleaning the lense using a cd lense cleaning kit/cd. this usualy helps. if it doesnt work, repost
Dec 18, 2008 | Memorex Audio Players & Recorders
Durabrand CD Home System Model # HM3817DT - suffix no: E1/M1
if i turn my cd home system of i will have problems so it can turn on back. what can i do
Sep 01, 2008 | Durabrand STS92 System
Setting alarm
You can download the manual from the link below: http://emersonradio.com/owners/SmartSet%20Series/CKS3020_072706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Emerson CKS3020 Clock Radio
Display Off/Wave won't turn off
I just purchased this clock too, and I can't get the Wave to turn OFF ! I have my alarms set to wake to radio...the Wave function is supposed to only function if you have the clock set to wake to buzz.
I may have to put a piece of duct tape over the Wave sensor to disable it.
Jul 15, 2007 | Emerson CKS3020 Clock Radio
Emerson Smartset Clock Radio Logo
122 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
