Question about Brookstone Pure-Ion (506840) Air Purifier
White dust or substance is forming on our air purifier when we us
We clean the filters, then a white dust like substance forms on the air purifier. Also, when I wipe the built-in filters - not sure if they're filters, it's black.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The only possible source of the white dust/flakes would be dried up detergent (if used) when you cleaned the separable filters or most likely gummed up or solidified and burned/ionized airborne pollen, smoke, dust, bacteria and mold. Since there are no replaceable filters or parts, cleaning is the only method every 1-4 weeks depending on usage/air conditions . Additionally, the stainless collector plates likewise has to be cleaned otherwise, residual dust, dirt and others of the like would transfer to the filters and hence they must be cleaned again. It has bee reported that you can run the filters through a dishwasher.
Good luck and thank you for using FixYa.
Posted on Feb 22, 2009
    Genius:
  • 1,550 Answers
With what have you cleaned . Did you use the cleaning solvent or some other thing to clean the filter .
Remove the filter and once again clean with dry and clean clothes .
Fresh air is making a popping sound
Carefully examine the plate. If there are black burnt spots next to the wire, it needs to be replaced. Otherwise, cleaning it will stop the popping sound.
May 13, 2012 | Ecoquest Fresh Air Air Purifier
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
Why is my Oreck XL is my air purifier arcing?
If it was just clean recently, it's probably picking up dust particles and that's what you hear or see arching, like a bug zapper.And conversely, if it has been cleaned recently, dust particles on the filter are breaking off and getting zapped. In which case, you need to clean the filter.
Thanks for choosing FixYa.
Aug 25, 2011 | Oreck XL Professional Air Purifier
Will the Breeze AT help with the house hold dust kicked up by 2 St. Bernards etc. Also, can I clean the filter myself?
It should help to reduce the amount of air borne dust in your home. The filter can be cleaned either by vacuuming the lint screen or removing it and washing it with hot water and using a toothbrush to remove any dust buildup. Clean the purification plate with a 50/50 solution of water and amonia and a toothbrust to clean the grids. Allow both to dry completely before reinstalling. Make sure that the lint filter has the clip depressing the safety switch when reinstalling it. Hope this helps you.
Oct 27, 2010 | Ecoquest Breeze AT Living Air Purifier
Manual
no just a switch on cover that has to be pushed in by the cover before it will be safe to turn on
Apr 04, 2010 | Brookstone Pure-Ion UV Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Jan 12, 2009 | Oreck XL Professional Air Purifier
Annoying ticking
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Dec 02, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Manual for Oure Ion Advanced
the clean filter light will reset itself once the filter is completely clean. Try dust off the areas where the filter is inserted into as well.
Oct 30, 2007 | Brookstone Pure-Ion UV Air Purifier
Cleaning the fresh air purifier
You have cleaned the purifier. Now on the front there is a reset button next to the power button push that to reset cleaning cycle.
Oct 10, 2007 | Ecoquest Fresh Air Air Purifier
Brookstone Pure-Ion  (506840) Air Purifier Logo
149 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
