Question about Sony Televison & Video
Internal battery in Sony VCR.
Could anyone tell me if there is an internal battery in my older Sony VCR?? It is mode number SLV-373 UC. It used to save the time and everything when the power goes out, but now it doesn't and hasn't for some time. I thought maybe I could replace an internal battery to fix this problem.
Thanks for any help....
  • 4,234 Answers
These units use a large valued capacitor rather than a battery. If memory serves me corectly, on these units the cap is located on the front panel board. It is usually either a 1 farad cap or a 2.2 farad cap at 3V.
Dan
Posted on Feb 23, 2009
Instruction manual for sony slv se730 vcr
Have you tried the Sony Website? They often have free PDF's of them.
Nov 11, 2011 | Sony SLV-SE730 VHS VCR
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Settings disappear
I suspect the internal backup battery is faulty inside the machine. Sometimes it can be an actual battery soldered to the circuit board otherwise look for a low voltage high capaticance capacitor - for example 3.5v 10F. If you dont know how to check for these things then find a competant technician. Good luck.
Oct 04, 2008 | Sony SLV-SE820 VHS VCR
Remote control gives wrong signals
You should goggle the model number and check if they have supplied you with the correct remote control.
Nov 04, 2017 | Sony SLV-ED40 VHS VCR
Sony SLV N80
DId you open up the VCR and take the quarters out?
Dec 05, 2007 | Sony SLV-N55 VHS VCR
VCR Eats the tapes
Often the "Pinch Roller" type Tape Drive can "Dry Out" and it slips. this causes the tape to get all screwed up.. It could also be a belt that turns the capstan.. Or even a thing called the "Mode Switch" In any event Ya probably be best to take it in for repair as it's not really a "Homer" I suggest ya get a quote and an explanation, and see if it is economically worthwhile?
Aug 22, 2007 | Sony SLV-D550P DVD Player/VCR
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony VCR date only goes up 2006
I have 2 SLV-696HF units that won't work after 2007. I have had people tell me that I'll have to "find" a previous calendar that will work, since there are only 14 different calendars in our Gregorian system, 7 for non-leap years & 7 for leap years. The problem we have with this, is that the internal VCR calendar won't roll BACK far enough. I wonder if SONY has a way of flashing these units to fix this problem?
Jan 12, 2007 | Sony SLV-M91HF VHS VCR
Televison & Video Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
