Question about Dell C600 (002UH) Motherboard
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
I think you should check your laptop, i think the laptop's battery slot have some problem. Or if you want to buy a new dell latitude c600 battery, you can buy here dell latitude c600 battery
Posted on Aug 10, 2010
  • 530 Answers
Hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Posted on Feb 23, 2009
4 Suggested Answers
  • 38 Answers
SOURCE: dell c600 latitude
Yes they can be replaced. They plug into the motherboard. The hard part is getting into the case. there are resources online that show how to dissasemble. You will need to remove the keyboard to access video board. Replacements are easy to find and not too expensive
Posted on Jan 18, 2008
  • 59 Answers
SOURCE: My laptop (Dell Latitude D600)is not charging.
laptop is bad, happened to me, try warranty if possible
Posted on Oct 21, 2009
  • 11800 Answers
SOURCE: there is only 1 usb port on this computer, and Im
All USB sockets support that, it's in the standard. But for ease of use it will be better to use a hub. But because it's such an old laptop it will surely be an 1.1 type, and the speed will be very slow.
Posted on Dec 26, 2010
BATTERY WON´T CHARGE ON DELL C600
It is possible the battery where the contacts from the laptop fit into or the gold colored contacts themselves need to be repaired. Worst case, the spill short circuited the contacts on the board, in which case you will have to replace the board. I would suggest really cleaning the gold contacts on the laptop and the small slots on the battery itself with a Q-tip with a little bit of rubbing alcohol on it. Please make sure both areas are totally dry before reassembling the battery.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell Latitude C610/C600 Notebook
Cannot figure out where the battery is located on my dell latitude c600 laptop computer to be able to replace it!
Hi friend,
You need to check in back side of laptop...it is near by your printer port...you can replace your battery...
Dec 25, 2009 | Dell Latitude C600 Notebook
Dell C600 No boot, all lights on exept battery charge indicator
u may need to source a main board..and change it..hope it's still under warranty ...
May 22, 2009 | Dell Latitude C600 Notebook
Dell c600 problems with: charging/keyboard/pointing device
you can try online antivirus scan firstly, like NOD.com, AVG.com. If everything is OK, try to reinstall OS,or RMA
Feb 13, 2009 | Dell Latitude C600 Notebook
MY DELL LATTITUDE C600 TURNS OFF AUTIMATICALLY
hi there, you can try this unplug the powercord from the pc and remove the battery and than press the power key than replace the battery adn plug in the power cord and let it charge for a hour or so and than try it again. if it boots good if not try to press the del key right after you turn on the unit and check the settings of bios to see what they are set at and try to set it to default or failsafe than save on exit and reboot and see what that does
Dec 18, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Help
Hi
I am afraid Dell did no plan Windows XP for Latitude C600 thus Dell has not made released certified drivers.
Generally, Windows XP SP2 should have most of the drivers built in. Reply if you have device(s) which lack drivers and I will get you the drivers at best effort.
Also, try Windows 2000 drivers. Normally it should work
Latitude C600 Windows 2000 driver list -
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=LAT_PNT_P3C_C600&hidos=WW1&hidlang=en
Mike
Apr 19, 2008 | Dell Latitude C600 Notebook
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell C600 (002UH) Motherboard Logo
607 people viewed this question
Alun Cox
