Question about Refrigerators
Fridge dont get cold.
Hi
I have a Hotpoint RLA34 fridge, the light comes on and it makes noise but it dont get cold even though I have the teperature control on the highest number. Any idea of what the problem could be.
Thanx
  • j_b3 Feb 23, 2009
    reply to waynephatg - yes the motor is running.
  • waynephatg May 11, 2010
    Is the compressor/motor running at the back?
  • 3 Answers
If the compressor is running then it could be one of the following:
The compressor isn't pumping properly. The thermosat has failed. It has lost refrigerant or there is a blockage.
Not alot of help I know but without seeing the fridge it's hard to say.
Posted on Feb 23, 2009
Can you tell me where the drip tray goes on the hotpoint rla34 fridge please
Usually at the bottom after you remove the kick bracket in front.
Jun 12, 2017 | Hotpoint Refrigerators
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
My hotpoint fridge RLA34 isnt keep my food cold
you'll cooling coils may be dirty thermostat may be going bad or it might be just a setting worse case a coolant leak requireing a repairman
Jul 30, 2012 | Hotpoint Refrigerators
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer and frige dont get cold and making a noise
Hi Thanks For The Question. Is The fridge Cold.If Yes Check In Fridge For The Noise. If Not In Fridge Pull Fridge Away From Wall, Remove Back Panel Clean All Coils Thanks The Appliance Doc
Sep 12, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
HOTPOINT RLA30 FRIDGE
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Model # PLFU1778ES Fridgidaire
tilting it would not do any harm while running the tilting theory is if you lay a fridge over on its side the oil in the compressor can run into the suction tubing and it is recomended not to plug it in right away . this is to alow the oil time to run back into the compressor housing. did you posibly loose some air space around the freezer. refrigeration is all about the removal of heat. if you block the air flow around the unit it may not be able to aceave the low teperatur set points. hope this helped
Dec 11, 2007 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
292 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
