Question about Husqvarna Garden
Husqvarna 345 chainsaw chain doesn't move freely and heats up
My husqvarna chainsaw cranks good but after removing he brake the saw will work for a very short time but then it heats up and heat/light smoke comes from the sprocket area.
  • Anonymous Mar 15, 2014
    Chainsaw runs but only with short bursts of throttle
  • 181 Answers
Has the chain ever came off the saw?and i'm going to assume that it is the correct chain for the saw...reason i ask about the chain comming off the saw is that when it does the driver have a tendency to become nicked and will heat up the clutch because the saw is trying to drive the chain links through the chain slot.also you need to look at the drive sprocket to see if there is any wear on the teeth....also over tighting the chain will cause the clutch to heat up.
Posted on Feb 24, 2009
What will cause the chain to stop turning when clutch(brake)cover gets final tightening?
If this is a Husqvarna, then it is crucial to make sure your brake is not set, when removing the cover. Rotate the blade to make sure it is moving freely, then remove the cover without setting the brake. However, as time went on, it still happened occasionally and seemed to be a defect in the saw. I had a Husqvarna Rancher, which drove me berserk, until I removed it, entirely. Not recommending that last course of action, but it is something that is common to this saw.
Jan 07, 2015 | Garden
Unable to locate adjustment control for chain oiler model 345 husqvarna chainsaw
Not all 345 machines had an adjustable oiler, it is retro fittable if it does not, however if it hs an adjuster, the screw is located on the bottom of the saw between the cranckcase and the fuel tank, just below the sprocket, there will be an oil symbol and a - and + sign there, the pump is three position, for 13/15/18" bars.
Oct 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
How do you take the head of the engine
Depends on what model we are talking about, if it is a 340/345/350 you need to remove the fuel tank, the cylinder bolts are on the bottom of the crankcase, the crank is sanwiched between the cylinder and the tank assembly, so it is a full strip down to remove the cylinder.
Jul 03, 2011 | Husqvarna Forest & Garden No.967012396 345...
How to change the chain on chainsaw
Most saws are pretty much the same procedure.....here's a decent link. Some saws will give trouble if the brake is on when you remove the side cover so make sure the chain moves freely before removing the side cover.
Here's one on tensioning the chain...
Dec 07, 2010 | Homelite ZR10926 16" Chain Saw
Chain will not rotate; which part needs to be replaced?
Try to turn the chain by hand--if moves freely, the clutch assembly under the cover may be overly oiled. Remove the bar and chain, then wash the clutch drum and shoes with carburetor spray cleaner. Make sure the chain brake is not set. Hope this helps!
Sep 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
550 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
