Question about Electrolux EW1000i Front Load Washer
Error code 10E and 01E
My washer keeps nbreaking down and this error code shows on the screen
Code 01E: Water level becomes too high;
Code 10E: The drain is clogged, or the drain pump is blocked/defect.
Possible solutions:
- Check if the drain is blocked with something, and clean it;
- Check if the drain pump works, replace it (if necessary);
- Replace the Water Level Control unit.
Posted on Feb 12, 2010
My whirlpool frontload washing machine is not working it the service light keeps flashing anytime I turn it on and it show F08 can you help please
So this error means that the washer isn't detecting any water coming into the unit. Maytag uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Read more: http://www.justanswer.com/appliance/82v23-maytag-front-end-washer-e01-f08-codes-does-mean.html#ixzz3dusUoyhh found this helpful answer from an appliance technician on JustAnswer com
Jun 23, 2015 | Whirlpool Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
GE model washer keeps showing H20 Supply error code and will not fill with water
then replace the water inlet valve or perhaps the screen is plugged inside the hoses
Oct 13, 2013 | Hotpoint Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
  1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
  2. FH Error Code
  3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
  4. FL Error Code
  5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
  6. F02 Error Code
  7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
Dec 06, 2010 | Kenmore Washing Machines
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
F20 Error code
be sure to ck fill hoses make sure both are turned on all the way ..remove hose at washer end ckd screen inside inlet for sand/rust/gunk pull screen out to clean and be sure to reinstall it or you're asking for trouble down the road..also ck faucet end just in case someone installed one there 2..by the way just having cold water only on will cause same problem
Aug 26, 2008 | Kenmore 46462 Front Load Washer
Error
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test and setup
let me know what it tell you I can help...
Apr 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
WASHERS WILL START
GE Profile Harmony
3 press HELP
Let me know what the errors are I can help..
Mar 16, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Electrolux EW1000i Front Load Washer Logo
490 people viewed this question
Top Electrolux Washing Machines Experts
Electrolux
Electrolux
Tim Whalen
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
