Question about IBM ThinkPad A31P Notebook
LCD DEAD Can use laptop with external monitor, but will not work with screen
  • 502 Answers
This could be a board issue, backlight issue or inverter issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue, you can just order on inverter, they're 20 bucks on ebay, if that doesn't work replace the backlight. As much as I would like to be able to tell you a quickfix that will solve the problem you can either google for guides that show you how to replace the backlight or bring it in for repairs. Backlight repairs are somewhat difficult. If there is no image at all it's most likely a logic board issue which will cost 50% of buying a new one. Laptop Repair NYC.
Posted on May 17, 2009
    Novelist:
  • 148 Answers
Unfortuantely at this point, replacing the LCD or replacing the laptop will be your choices. Try ebay for parts to your laptop if you want to attempt replacement of the LCD. You may get lucky and find a dead laptop that is the same model as yours where the LCD still works; otherwise, replace the laptop. If you send it back to Lenovo (the company who deals with IBM's laptops now) it will cost you about as much as buying a new one to fix this one.
Posted on Feb 22, 2009
  • John Miller Jr Feb 22, 2009
4 Suggested Answers
harvester3
  • 181 Answers
SOURCE: Blank LCD Screen
Well, sounds like a couple of things if an external monitor works. First, toggle a couple of times between lcd and external just to make sure that it's not set to external only.
If that's no help, look closely at the lcd while the operating system is running. Can you see any image at all? If so (or if not) you have a bad inverter (we have them at the shop for around 25.00). The other possibilities are a bad backlight (which means a new lcd, about 75.00) or it's possible the lcd cable has simply came loose from it's socket.
That's about all it could be on these models if you're getting an external image. I'm using a T30 right now. They tend to have bad memory slots, but great machines.
Good luck
Posted on Nov 26, 2007
  • 12 Answers
SOURCE: Dim Laptop screen
It could either be your power settings dimming it (battery saver mode), or more likely when you replaced the screen, you replaced the backlight with the one that came with it. The replacement backlight is probably not as good as the one you had. You can try putting your other backlight in it (the backlight is that circuit board near the hinge that you plug in when you switch the screens out). Since it's going in and out, I'd check the power settings first though.
Posted on May 04, 2009
SOURCE: Thinkpad T30 - LCD Not working
I dropped my laptop and screen was verry hard to see unless u shined a bright light at it. the inverter just under the lcd screen happened to come unpluged. I dont know if i was just lucky or if this has happened to more people. I hope this helps some one else.
Posted on Dec 30, 2011
Can i just remove the monitor assembly toshiba laptop p5085d-s8935 and just use a n external monitor
You could do that. Here is an excellent guide to replacing that model laptop's lcd which will show you basically how to remove it as well.
http://www.laptopinventory.com/LaptopInventory.php/Toshiba/Satellite/P505D-S8935/LCD
Dec 07, 2012 | Toshiba Computers & Internet
Unable to view screen - computer starts up and no lcd usage. I tried connecting another monitor and doesn't work either. Could it be the video card. Thank you!
Press the combination keys Fn+F... key that switches on LCD or external monitor. If that solution does not work...it means that your video card chip is dead.
Feb 14, 2010 | Dell Inspiron B130 Notebook
Whilst in use went completly dead canot resart
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Nov 02, 2009 | HP Pavilion dv6000z Notebook
Ma acer aspire 5738z does not start at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
Oct 16, 2009 | Acer Aspire 5735 Notebook
My laptop monitor is not woking
Oct 16, 2009 | Computers & Internet
I have power out of adapter but laptop is completely dead; no lights come on at all.
Oct 16, 2009 | Toshiba Satellite A45-S150 Notebook
Dell latitude d500 had a power socket problem, but now resolved pc will not boot-up, drive spins-up, then nothing, completely dead display i think most likely scenario is mobo is fried, but open to...
Oct 10, 2009 | Dell Latitude D500 Notebook
The screen is not going on all that shows up is a black screen with a white slash mark flasing
Oct 10, 2009 | Dell Inspiron 2200 Notebook
SCREEN WONT TURN ON
Connect an external monitor (CRT or LCD) to the laptop's "VGA-out" port. Then, turn your laptop on. Does it show the usual "start-up" screen, on the external monitor? If so, then either your laptop's screen is totally-dead, or the "LCD-inverter" (a $20 part that takes $50 for a technician to replace) needs replacement.
Or, does your laptop have a key-sequence (LCD-screen-only, LCD-and-external, external-only) that needs to be used to select LCD-only mode?
Apr 23, 2009 | Computers & Internet
Compaq Presario laptop
First attach laptop to an external monitor and using the FN/ F keys toggle back and forth to the external display. If the external works OK then the video display adapter is fine and the problem is the TAB welds on the LCD. Time for a new LCD.
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
